There is an extra line in this Drawing marked 'A'.
How do I avoid it?
FCStd is here https://1drv.ms/u/s!ArMxdUYEh9fKwBri9KC ... W?e=PkHxmC.
Thanks
Extra Line in Drawing
- 220120 Driver Sprocket Dwg.pdf
- (392.29 KiB) Downloaded 20 times
"It is much harder to simplify than to complicate."
Joseph Kimble
Joseph Kimble
- Shalmeneser
Re: Extra Line in Drawing
A ? Where ? What ?
- Shalmeneser
- Capture du 2022-01-20 23-24-25.png (61.28 KiB) Viewed 965 times
- 220120 Driver Sprocket_SHALM.FCStd
- (947.21 KiB) Downloaded 15 times
Thanks for trying.
- 220121 Shalmaneser's Drawing.pdf
- (355.69 KiB) Downloaded 19 times
Joseph Kimble
Joseph Kimble
- Shalmeneser
A : (in reference to other post ) : seam line = false ?
- Capture du 2022-01-21 00-13-41.png (11.1 KiB) Viewed 926 times
- SeamLine.FCStd
- (20.68 KiB) Downloaded 15 times
I don't know what you are trying to say.
I toggled off the seam line in your 3D model of a Cone and then created a drawing from the unseamly cone and the line is still there.
Joseph Kimble
Joseph Kimble
You probably changed the draw style in 3D view to shaded, but that doesn't switch the seamline off. The seam of an object is always there even if you don't see it; it is the base for the object as can be seen in wireframe mode.
You have to set in TechDraw SeamVisible=False.
That's what I did.
This was the light at the end of the tunnel:
https://forum.freecadweb.org/viewtopic. ... 69#p450127
That's a long road to a simple answer.
Thanks folks
Joseph Kimble
Joseph Kimble
