OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
I'm trying to use a Nested IF THEN in FreeCAD spreadsheets, but it doesn't appear to be working right.
I've used the following command where the user can enter 1, 2, or 3 in one cell to indicate that the value at this other cell will be 10, 20, or 30
=VarOpt == 1 ? VarChoice1 : VarOpt == 2 ? VarChoice2 : VarChoice3
I expected VarOpt == 1 ? Var Choice 1 to give me 10. If VarOpt == 1 failed, I expected it to go to the next level and evaluate VarOpt == 2. If that was true, then it would give me 20. If neither were true, it would give me 30
However when I implement it, I do not get what I expected. It seems like it only evaluates the last check. If I put in 1, it gives me 30, but if I enter 2 it does give me 20.
Is nesting not supported?
Also, I haven't been able to find any documentation on using AND or OR statements. Are they supported?
Finally, it would be nice to have an ELSE statement as well to give me a value if none of the other conditions are met.
[SOLVED] Nesting IF THEN statements and using ELSE AND OR in Spreadsheet
- NestedIFTHEN.FCStd
- (2.39 KiB) Downloaded 16 times
Re: Nesting IF THEN statements and using ELSE AND OR in Spreadsheet
You have to use parentheses to prioritize the expressions.
Interesting way of doing it.
=VarOpt == 1 ? VarChoice1 : (VarOpt == 2 ? VarChoice2 : (VarOpt == 3 ? VarChoice3 : VarChoice4))
Seemed to do the trick and I was able to add an additional level.
THANKS
THANKS
- (2.39 KiB) Downloaded 24 times
Is there a way to use OR or AND Booleans in the statement? Can do it the hard way, but if those are available, just makes the code a little cleaner.
I've searched for IF THEN in the forum, but because they are such common words, of course it does not give me much info. I looked in the Spreadsheet manual Spreadsheet Workbenchand expressions area and didn't see anything on this. It would be nice if someone could add some information about these in the spreadsheet manual as I expect this to be a common function used there.
But then again, if no one has asked up to now, maybe it isn't that common.
AFAIK AND and OR aren't available, so you have to go the long way.
If you have complex expressions, probably a good way is to have an intermediate truth table in the spreadsheet.
