Yes, that's the case here.
[BUG][0.20] "Open sketch in Section View mode" preference has no effect
Re: [BUG][0.20] "Open sketch in Section View mode" preference has no effect
Yes, exactly that.
Also changing the section view while editing a sketch (hotkey Q, S), the section is applied (as you can see in my screenshots), but it does not change the "Section View" property of the sketch. Should the property update immediately or after closing the sketch?
It's as if the property and the sketcher option are setting two different parameters (with the latter not being saved to the sketch).
I forgot: I can well switch to section view if I am in Sketcher.
As it should not IMO. If you know that you need that for a specific sketch or for them all there are already mechanisms for that.
This is really weird. Did you tried to disable add-ons? I absolutely can't reproduce this.Lupin wrote: ↑Mon Jan 24, 2022 5:25 pm Yes, exactly that.
If I set the environment variables
FREECAD_USER_HOME
FREECAD_USER_DATA
FREECAD_USER_TEMP
to a completely new directory, and create a new such model, then automatic section view works. It still fails if a sketch is opened that was written with my default directory and config in use,
So it must be something in the files.
The file SectionViewVanillaFCStd works as expected and was created in a vanilla config directory.
The file sectionView.FCStd doesn not work properly.
FREECAD_USER_HOME
FREECAD_USER_DATA
FREECAD_USER_TEMP
- sectionView.FCStd
- (7.68 KiB) Downloaded 18 times
- sectionViewVanilla.FCStd
- (10.25 KiB) Downloaded 20 times
Congrats for this. Now I have a clue. If View/ShowSupport of the sketch is 'false', then the section doesn't work.chrisb wrote: ↑Tue Jan 25, 2022 12:21 am If I set the environment variables
FREECAD_USER_HOME
FREECAD_USER_DATA
FREECAD_USER_TEMP
I'll dig based on that.
Also in your case it looks like using a PartDesign/Primitive plays a role. Will narrow it down.
EDIT : After some test, it looks like having View/ShowLinks to 'false' creates the issue. EDIT2 : confirmed on different situations.
OK, I let this cool down because I was expecting a painful analysis.
This probably was a good idea, because with fresh eyes it took to me 10 seconds to find the problem.
But now admittedly, I feel like the worst coder ever. 2 spaces got my head.
Fixed in https://github.com/FreeCAD/FreeCAD/pull/5438
