tangent constraints are kinda slow and choppy
I am pretty new to FreeCAD, and I was making a pretty complex sketch that used a lot of tangent constraints.
I noticed hat moving pieces of the sketch or rotating it around a constrained point seemed pretty slow and choppy.
I realized that the sketch was being marked as fully constrained, even though there are actually 2 possible solutions for an arch with two tangent constraints at its end points, one mirrors the other.
I was able to improve the choppiness by replacing the tangent constraints with parallel or perpendicular constraints on construction lines that were built as radius of the arch.
It seems though that the choppiness still appears when trying to do a full rotation, especially when crossing the axes with the point i am dragging.
Is this a bug, or is there something I can do to solve the issue?
One thing I considered is the use of an "always clockwise" or "always counterclockwise" version of angle definition, but I couldn't find that.
There is an example attached to this message. OS: Debian GNU/Linux bookworm/sid (GNOME/gnome-xorg)
Version: 0.19.
Python version: 3.9.7
Qt version: 5.15.2
OCC version: 7.5.1
Version: 0.19.
Qt version: 5.15.2
OCC version: 7.5.1
Last edited by 0000matteo0000 on Sat Jan 22, 2022 11:47 am, edited 1 time in total.
Re: tangent constraints are kinda slow and choppy
Hi and welcome to the forum!
The attachment is missing.
edited to add it inline
Hello 0000matteo0000, greetings to the Community!
Attached is your file in which the correct sketch has been added which includes 3 "tangency" constraints, one "dimensional" and one "point onto object".
- tangent_constraint_test.FCStd
- (9.67 KiB) Downloaded 16 times
While the constraint scheme in your example is appropriate. I think the OP was talking about rotating the sketch geometry. This can't be accomplished with your constraint scheme.
To the OP point. The observed behaviour, as noted, is dependant the constraint scheme and how the solver reacts as the a self constrained set of geometry (i.e. geometry constrained to it self, but not the coordinate system). The solver equations are being solved as you rotate.
Yes, I was talking about rotating it, also the proposed sketch if allowed to rotate seems to perform better and has a third tangent constraint I am not allowed to add in my version of FreeCAD without it being marked as redundant. What was your FreeCAD version?
Hello drmacro, greetings to the community!
Yes, thanks for letting me know, I had not correctly interpreted the request, in any case it is sufficient to eliminate the "point onto object" constraint on the horizontal axis to have the same effect, it is not necessary to create a construction line, you will get it anyway a degree of freedom due to the 3 tangencies and the dimensional constraint and therefore in this case there will be rotation.
- (9.95 KiB) Downloaded 6 times
- tangent.png (160.57 KiB) Viewed 985 times
so is there any way to make orientation-aware constraints?
Some are (angle). Most aren't.0000matteo0000 wrote: ↑Sun Jan 23, 2022 11:37 pm so is there any way to make orientation-aware constraints?
Depends on what your definition is.
If you select only a vertex in the lower left quadrant and put on horizontal and vertical constraints, the values will be negative.
But that doesn't really induce the solver to keep them negative.
