I'm a beginner with FreeCAD (0.19, Fedora). After some research and video tutorials I managed to design my part, expect one last step.
I created 2 lofts, to represent the outside and the inside of what I call the tunnel.
I now need to subtract the inside shape to the outside shape to create a big whole.
I tried to use the cut or the boolean buttons, sometimes after converting my lofts to solids, but this always ends up with something not expected.
I attached my project file. Here is a view of what I want after playing with the visibility but I can't achieve the same in an exported STL file.
How to subtract this loft to another?
- project.FCStd
- (74.57 KiB) Downloaded 13 times
- Shalmeneser
Re: How to subtract this loft to another?
Lofts : Solid=true
Why do you need bodies and parts ?
├ Cut (Cut)
│ ├ TunnelOutside (Loft)
│ │ ├ Face (Face)
│ │ └ Face001 (Face)
│ └ TunnelInside (Loft)
│ ├ Face002 (Face)
│ └ Face003 (Face)
- project_SHALM.FCStd
- (79.39 KiB) Downloaded 18 times
- Capture du 2022-01-21 23-57-52.png (44.55 KiB) Viewed 1348 times
- Shalmeneser
└ Body (Body)
├ Pad (Pad)
│ └ Sketch (Sketch)
├ AdditiveLoft (AdditiveLoft)
│ ├ Sketch (Sketch)
│ └ Sketch001 (Sketch)
└ Pad001 (Pad)
└ Sketch002 (Sketch)
- Capture du 2022-01-22 00-10-28.png (29.41 KiB) Viewed 1340 times
- project_SHALM2.FCStd
- (54.33 KiB) Downloaded 18 times
- Shalmeneser
- project_SHALM3.FCStd
- (84.73 KiB) Downloaded 25 times
Many thanks Shalmeneser.
I know I shouldn't use multiple bodies but at my level that's the way I found to do more complex shapes.
Can you tell me what you did to my original file to get this result? (your first file)
I will take the time to have a deep look of your other files to understand how I should have done that.
- Shalmeneser
A loft in Part can be just a face or a solid.
Part create different solids and you need to fuse / cut / intersect them to get the resulting solid.
But 2 bodies and 1 part object do not give 1 object. You need to fuse them all. (Or select them all before export)
