OS: Windows 10 Version 2009
Version: 0.19.24267 +99 (Git)
Branch: Branch_0.19.3
Hash: 6530e364184ce05ccff39501e175cf2237e6ee4b
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
I'm trying to make a visor for a helmet and to do so requires me to bend a curve around another two curves until it meets another curve (yes lots of curves). But sweeping on two rails does not do the trick as the end result is not usable. I'm aware that it may be because the rails are connected at an angle. There are a few other methods to make the same shape that I'm trying to achieve but I can't get any of them to work. To be precise I'm trying to make a 3D curve connecting 4 curved sketches. So after sweep on two rails failed I tried a Gordon surface, but this will crash my program any time I try, when creating the Gordon surface I selected the two "ribs" and the two "spines". After that failed I tried discretizing each wire and then forming a surface from their point clouds. This did make a surface between all 4 lines but none of the 24 combinations of connections made a shape that was usable. I tried making a surface from 2, 3, 4 boundary edges (4) which also crashed my program. I tried adding another line to create a section inside of where I wanted my 3D curve and doing a sectional surface. That almost worked but for an unknown reason one of the curves twisted a 180. The only solution that even was able to cover the gap where the visor is without crashing or doing something unintended was creating a surface between two edges. However this didn't follow the rails I set up and there was no way to do so. Anyways, what I'm asking here is is there a way, to make a curved surface between four curves?
Sweep on two rails is making an uexpected shape.
- RPHelm-v0.1-atmpt5.FCStd
- The helmet
- (978.02 KiB) Downloaded 21 times
- Here I've created a surface between two edges, which looks fine but isn't able to confine to the other two rails I need it to follow (I really only need it to follow the profile of the visor rail the other one is optional)
- Screenshot 2022-01-22 001105.png (229.89 KiB) Viewed 2653 times
