Invalid geometry
perot
Invalid geometry
Post by perot »
What's wrong with this exceeding simple geometry? When I apply Part:CheckGeometry on this object, it reports problems associated with the contour of the drill hole's opening. Somehow this is related to the cut that removes the back part of the base cylinder. If I dissolve that cut, and check the cyclinder with the drill hole, everything's fine, even though the dissolved cut is entirely unrelated to the drill hole (it does not cut through the drill hole, nor effects it in any other way).
So, why is there a problem, and how to avoid it?
This is of course a simplified version of a much larger model I have this problem with.
Cheers Peter
OS: Windows 7 SP 1 (6.1)
Version: 0.19.23578 (Git)
Hash: 50c3cbf00579dc4941ca743c25720d016b0453ce
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
problem.FCStd
(36.88 KiB) Downloaded 27 times
TheMarkster
Re: Invalid geometry
Post by TheMarkster »
Select this edge and apply a very small chamfer. I used 0.011 mm and it worked to resolve the issue.
Snip macro screenshot-297967.png (76.8 KiB) Viewed 1260 times
drmacro
Post by drmacro »
Interestingly, the same object done in Part Design with two sketches is fine... :?: :roll:
I have increased the cube to avoid all so called coplanar problems. To no avail. Then I swapped the sequence of subtractions and now it works without geometry errors.
noproblem_cb.FCStd
(11.78 KiB) Downloaded 15 times
perot
Post by perot »
TheMarkster wrote: Sun Jan 23, 2022 4:11 pm Select this edge and apply a very small chamfer. I used 0.011 mm and it worked to resolve the issue.
Indeed! How can complicating the surface make problems disappear. Scratching head ...
So later today I'll try that solution with my full model. There it'll require a bit of re-arranging, for which I do not have time right now. I'll get back on this.
Thanks a lot!
Cheers Peter
Errors shown in CheckGeometry are most often, but not always an indicator that something bad will happen in the future. Sou you can try to continue, similar as with the fillets, and see if the issue vanishes all by itself.
heda
Post by heda »
it has something to do with the large cylinder seam.
the orientation angle is at zero in the problem model, the same with chrisb's model, however in the problem model the seam is no longer visible - it has magically disappeared, whereas it is visible in chrisb's model.
you probably do not need to remodel as such, your model starts working when the angle is 94 and above.
(maybe some occ guru will say why this is obvious and why it has to be this way :-))
Snip macro screenshot-7a9ec4.png (28.45 KiB) Viewed 1184 times
kisolre
Post by kisolre »
As always Refine=True is the reason...
perot
Post by perot »
chrisb wrote: Sun Jan 23, 2022 5:03 pm I have increased the cube to avoid all so called coplanar problems. To no avail. Then I swapped the sequence of subtractions and now it works without geometry errors.
I noticed this too, by now. Unfortunatly, swapping the subtractions is not an option, as I need the object with the drill hole, but the backside not cut away, in another context too (as a clone).
I also noticed another way of avoiding the problem, which may be applicable in my full model. If the base cylinder is rotated by 180° about it's axis, the problem goes away. For this there is no need to disassemble the tree, you just select the base cylinder and enter 180° under Properties/Placement/Angle. For the model proper, this is a no-op, as the cylinder is rotated about it's symmetry axis. However, Open Cascade's cylindrical surfaces always have a "seam" along the side, and this seam gets rotated to the other side, where in the model I posted it gets cut away.
Cheers Peter
PS.: Originally, I thought the seams exist because every surface in OpenCascade needs to be a simply connected manifold, but I realised that that does not explain the seams on spheres. Does anybody know more about the seams? Seems it'd be beneficial to understand them better.
perot
Post by perot »
chrisb wrote: Sun Jan 23, 2022 6:17 pm Errors shown in CheckGeometry are most often, but not always an indicator that something bad will happen in the future.
That was my experience too, so I aquired the habit to, from time to time, CheckGeometry all the objects I created, and if possible, fix the ones with problems.
Cheers Peter
