20:54:56 Traceback (most recent call last):
<class 'Base.FreeCADError'>: PropertyFileIncluded::SaveDocFile(): File '/Users/danielstaple/Library/Caches/FreeCAD/Cache/FreeCAD_Doc_6ceb41bb-40b9-4f78-bd67-0b1081ff3787_1a3e58_14737/A4_Portrait_blank.svg' in transient directory doesn't exist.
What is frustrating, is that if I tick the "...", it doesn't navigate back to the templates dir as that is in the FreeCAD package, and this window doesn't have "show package contents" enabled. In this mode - I am unable to save the work.
The workaround seems to be to open the dialog (with 3 dots), then in a separate Finder window navigate to the FreeCad(AppContent)/share/Mod/Techdraw/Templates, and drag this location into the open file dialog.
I've seen it twice now. Both I was working with multiple drawings, in multiple files, and had altered the dimensions of a sketch underlying a body that was projected into techdraw.
Version info:
OS: macOS 10.16
Version: 0.20.27078 (Git)
Python version: 3.9.9
Qt version: 5.12.9
OCC version: 7.5.3
Locale: C/Default (C)
