Issues rendering Arch labels in TechDraw view
psadauskas
Post by psadauskas »
I have a Arch plan with TechDraw page with a view of it. I have several Dimension labels, and those render fine. If I try to add a "Text" or "Label", however, it stops rendering the view in the page, and I get errors on the console.
Adding a "Label" gives me:
16:00:19  DVS::onChanged - ��>j� - SVG for Symbol is not valid. See log.
16:00:19  Error - Could not load Symbol into SVG renderer for ArchView001
Adding a "Text" gives me:
16:04:51  Traceback (most recent call last):
  File "/tmp/.mount_FreeCARsKOei/usr/Mod/Arch/ArchSectionPlane.py", line 545, in getSVG
    svg += Draft.get_svg(d,
  File "/tmp/.mount_FreeCARsKOei/usr/Mod/Draft/draftfunctions/svg.py", line 676, in get_svg
    tstroke, fontsize, n,
<class 'UnboundLocalError'>: local variable 'tstroke' referenced before assignment
16:04:51  Recompute failed! Please check report view.
To reproduce, open the file in FreeCAD 0.20, and in the tree view, drag any of the labels to the "New" group. Opening the file in FreeCAD 0.19 and doing the same works as expected.
OS: Fedora 34 (KDE Plasma) (KDE//usr/share/xsessions/plasmax11)
Version: 0.20.27078 (Git) AppImage
Branch: (HEAD detached at bcdd926)
Hash: bcdd926686f2245fe60baface1cce1ab3dff7a5b
Python version: 3.9.9
Qt version: 5.12.9
OCC version: 7.5.3
foundation.FCStd
(499.24 KiB) Downloaded 19 times
Roy_043
Re: Issues rendering Arch labels in TechDraw view
Post by Roy_043 »
Confirmed.
This recent commit is the cause I think:
https://github.com/FreeCAD/FreeCAD/comm ... 5659f9ee4a
If you try to add an Arch_Axis object to the "New" group there is an error as well:
10:23:58  Traceback (most recent call last):
  File "D:\BKG_Tmp\FreeCAD_0.20_Last_Conda\Mod\Arch\ArchSectionPlane.py", line 545, in getSVG
  File "D:\BKG_Tmp\FreeCAD_0.20_Last_Conda\Mod\Draft\draftfunctions\svg.py", line 699, in get_svg
    tstroke, fontsize, fn,
10:23:58  Recompute failed! Please check report view.
yorik wrote: pinged by pinger macro
Yorik can you have a look?
OS: Windows 8.1 (6.3)
Version: 0.20.26761 (Git)
Python version: 3.8.12
Qt version: 5.12.9
OCC version: 7.5.3
yorik
Founder
Post by yorik »
Indeed there were cases where this tstroke stayed undefined. With git commit e6b7c0e5f9 both errors should be fixed
Roy_043
Post by Roy_043 »
Thanks.
alexF
Post by alexF »
First of all, thank you for developping FreeCAD!
I have probably a similar Problem with Draft Label in Techdraw.
Adding a Draft_Label gives me:
18:09:51  Cette fonction sera obsolète. Veuillez utiliser 'get_svg'.
18:09:51  DVS::onChanged - H�T$L�D$L�L$ SUVW�8 - SVG for Symbol is not valid. See log.
18:09:51  Error - Could not load Symbol into SVG renderer for DraftView
to reproduce the error :
### Begin command Std_Workbench
Gui.activateWorkbench("BIMWorkbench")
### End command Std_Workbench
Gui.runCommand('Draft_Label',0)
_label_ = Draft.make_label(target_point=FreeCAD.Vector(-1700.9262594208005, -837.9066751926948, 178.25038011410697), placement=FreeCAD.Placement(FreeCAD.Vector(674.7998387378136, 2029.951927218433, 2028.8143436701757), FreeCAD.Rotation(0.44601488682286866, 0.11950894873610823, 0.229574936987557, 0.8567868344100226)), label_type='Custom', direction='Horizontal', distance=-1957.09865195767)
# Gui.Selection.addSelection('Sans_nom','dLabel')
Draft.autogroup(_label_)
FreeCAD.ActiveDocument.recompute()
Gui.activateWorkbench("TechDrawWorkbench")
### Begin command TechDraw_PageDefault
App.activeDocument().addObject('TechDraw::DrawPage','Page')
App.activeDocument().addObject('TechDraw::DrawSVGTemplate','Template')
App.activeDocument().Template.Template = 'C:/Program Files/FreeCAD 0.20/data/Mod/TechDraw/Templates/A4_LandscapeTD.svg'
App.activeDocument().Page.Template = App.activeDocument().Template
### End command TechDraw_PageDefault
### Begin command TechDraw_DraftView
App.activeDocument().addObject('TechDraw::DrawViewDraft','DraftView')
App.activeDocument().DraftView.Source = App.activeDocument().dLabel
App.activeDocument().Page.addView(App.activeDocument().DraftView)
App.activeDocument().DraftView.Direction = FreeCAD.Vector(0.410,-0.709,0.574)
### End command TechDraw_DraftView
# Gui.Selection.clearSelection()
# Gui.Selection.addSelection('Sans_nom','DraftView')
Draft_label_techdraw_problem.FCStd
(22.88 KiB) Downloaded 3 times
OS: Windows 10 Version 2009
Version: 0.20.27422 (Git)
Hash: d938733eaf2c2ce7cb18d1cbb56147185c473530
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Locale: French/Switzerland (fr_CH)
Coordialement,
