So the documentation shows how to install OpenSCAD but when you try to open an .scad file there is no option to open such. The documentation says it is possible. I have seen some reference to this problem but I have not seen an acknowledgement that this is a bug or any resolution. I am trying to import some files from thingyverse which are .scad files. One I tried to export as a csg file but this obviously did not work well. There were multiple errors and it tried to download DXF files or some thing from github. And the model is completely broken.
This is what was reported multiple times:
19:37:36 downloading https://raw.githubusercontent.com/yorik ... olorMap.py ...
19:37:36 downloading https://raw.githubusercontent.com/yorik ... Objects.py ...
19:37:36 downloading https://raw.githubusercontent.com/yorik ... Library.py ...
19:37:37 downloading https://raw.githubusercontent.com/yorik ... fReader.py ...
19:37:37 DXF libraries not available. Aborting.
19:37:37 opening D:\Temp\fc-06064-185501-000015.dxf...
19:37:37 Traceback (most recent call last):
File "D:\Program Files\FreeCAD 0.19\Mod\OpenSCAD\OpenSCADFeatures.py", line 503, in execute
shape = OpenSCAD.OpenSCADUtils.process_ObjectsViaOpenSCADShape(fp.Document,fp.Children,\
File "D:\Program Files\FreeCAD 0.19\Mod\OpenSCAD\OpenSCADUtils.py", line 604, in process_ObjectsViaOpenSCADShape
return process2D_ObjectsViaOpenSCADShape(children,name,doc)
File "D:\Program Files\FreeCAD 0.19\Mod\OpenSCAD\OpenSCADUtils.py", line 547, in process2D_ObjectsViaOpenSCADShape
face = importDXFface(tmpfilename,None,None)
File "D:\Program Files\FreeCAD 0.19\Mod\OpenSCAD\OpenSCAD2Dgeom.py", line 485, in importDXFface
layers = importDXF.processdxf(doc,filename,False,False) or importDXF.layers
File "D:\Program Files\FreeCAD 0.19\Mod\Draft\importDXF.py", line 2191, in processdxf
drawing = dxfReader.readDXF(filename)
<class 'AttributeError'>: 'NoneType' object has no attribute 'readDXF'
[SOLVED] OpenSCAD
[SOLVED] OpenSCAD
Reason: Added [Solved] to thread title
Re: OpenSCAD
You need to set the path to the OpenSCAD executable in the preferences (OpenSCAD_Preferences). And, probably, restart FreeCAD.
Re: OpenSCAD
Could you please report your FreeCAD version information (instructions here)? We've been doing a lot of work on the OpenSCAD importer in this development cycle.
Re: OpenSCAD
OS: Windows 10 Version 2009
Version: 0.19.24267 +99 (Git)
Branch: Branch_0.19.3
Hash: 6530e364184ce05ccff39501e175cf2237e6ee4b
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Re: OpenSCAD
The openscad path is set to the openscad.exe file...
Re: OpenSCAD
Miraculously it seems to work now not sure what changed...
