Hole in Part Design: Hole Shaft tolerance
pasquale.papa
BUG?? - Hole feature: hole/shaft tolerance
Post by pasquale.papa »
Dear all,
I'm using the FreeCAD 0.19.3.
I've noticed that when the threaded option is unchecked, the tolerance class is not selectable (It is in 0.18 Version). I think this is an error, because the tolerance class should be available only for the "not threaded holes" in order to define the hole/shaft coupling.
Let me have your opinions
24-01-2022_HOLE CLASS TOLERANCE.jpg (87.56 KiB) Viewed 972 times
Re: Hole in Part Design: Hole Shaft tolerance
Check in 0.20.
I have merged your topics. Check them and tell me which one to delete.
pasquale.papa
Help on using FreeCAD is good. How Can I check the post?
pasquale.papa wrote: Tue Jan 25, 2022 8:40 am Help on using FreeCAD is good. How Can I check the post?
They are both at the top of this topic. You can just look at them or you can compare their source texts, or make binary comparisons of the images or something else. On first glance they look equal, but I don't want to check this in detail.
pasquale.papa
They are equal. Delete the first one.
Thanks!
Done.
pasquale.papa
The issue is also present in 0.20
The Class Tolerance should be selectable for the not threaded Holes (i.e. when the Threaded option is unchecked)
