Pocket - Failed to validate broken face
Hi -
I'm a FreeCAD noob and ran into a problem I can't solve. I have searched the forum and found others struggling with this problem. None of the solutions seem to work for me tho.
Here is my version info:
OS: macOS 10.16
Version: 0.19.24366 (Git)
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Locale: C/Default (C)
This is the error message I'm getting:
It occurs when I try to make pockets from the sketch highlighted here:
I tried a few times. Strangely enough I managed to successfully make a pocket based on one of the two shapes. After modifying my sketch the error came up and didn't go away. Redrawing the sketch didn't help. If I draw a simple, unconstrained rectangle on the face, it's easy to make a pocket. But not with these shapes. What am I doing wrong?
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.3
- Headshell_v003.FCStd
- (31.83 KiB) Downloaded 11 times
Re: Pocket - Failed to validate broken face
Your sketch is not connected at most of the arc to line junctions.
It is necessary to connect all such points, generally with with a "coincident" or "tangent" constraint.
Merely placing the elements on top of each other does not create the connection.
The sketch validation tool from the main menu (Sketch >> Validate sketch) shows the error points.
You have used way too many dimensional constraints in an attempt to overlay the element ends. This is not only too busy but also ineffective.
Gene
Gene
- Shalmeneser
Use symmetry upon axis !
- Capture du 2022-01-24 23-17-07.png (31.89 KiB) Viewed 970 times
- Headshell_SHALM.FCStd
- (36.37 KiB) Downloaded 11 times
- Shalmeneser
* No zero-dimension !
* No twice the same dimension !
use geometrical constraint over dimensionnal constraint.
(you need to have less job to change one dimension value.)
- Capture du 2022-01-24 23-19-50.png (28.53 KiB) Viewed 963 times
- Capture du 2022-01-24 23-22-54.png (15.9 KiB) Viewed 963 times
Thank you for this guidance - GeneFC too, I take it you're saying the same thing. Also the symmetry upon axis is nice to know. I had been missing that but it greatly improves the workflow.Shalmeneser wrote: ↑Mon Jan 24, 2022 10:24 pm * No zero-dimension !
It worked like a charm:
Now my next hurdle: I'd like to make the corners of the pocket rounded. As if an ice cream scoop scooped it out of the metal, something like the front block in this image:
How can I make FreeCAD do this?
You can use Fillets. But you should know that these may have to be redone, if you later on make changes to previous steps; see the topological naming problem for details.
Thank you Chris. I had tried fillets, but keep getting this notification:chrisb wrote: ↑Tue Jan 25, 2022 8:58 am You can use Fillets. But you should know that these may have to be redone, if you later on make changes to previous steps; see the topological naming problem for details.
My problem is either that I don't know what face or edge to apply the fillet to (tried many), or that my model has one or more other mistakes in it. Would you have any idea what I can try to get those nice round edges?
- (42.64 KiB) Downloaded 8 times
Thanks for the heads up about having to redo them after subsequent changes. I'm not worried about that for this model, as likely this is the last change I'll make to it before sending it off for production.
The fillet must not consume all of the adjacent face. Thus a radius of 0.499 works, 0.5 fails.
Perfect, done.
