Forgot to add "and use an array for the bolt holes."
MontyL
path array behavior
- wandererfan
Re: path array behavior
mmm...
negative center mass ????
Move center mass to Zero makes sense to me.
Althought... I'm thinking that FreeCAD should make no such assumption on the user's behalf as the exact result, although predictable, may not be the desired one.
MontyL
MontyL
There is a way to change the origin point of an object, provided its Shape property is not immutable.
Move it to the origin, putting the new desired origin point on the origin.
Select the object, Ctrl+Shift+P
In the python console:
Object should now be on the origin with its origin point at the origin.
obj.Shape = obj.Shape.copy().transformShape(obj.Placement.toMatrix(),True)
obj.Placement = App.Placement()
