[Solved]Options to only being able to select edges/vertices/faces?
- pathfinder
maybe I confused this with another program, but wasn't there an option to toggle whether you only want vertices, edges or faces to be selectable? I can't find it anymore.
If there isn't one, I'd like to make a feature request
With more complex objects, sometime selecting edges or vertices can be a hassle. I know that the draw styles can be used for edges, but for vertices, it's just a mess of points without any context.
- Shalmeneser
Re: Options to only being able toselect edges/vertices/faces?
I don't think.
Which context ? 3D view or sketcher ?
There is a selection gate.
Now you can only select Edges and Faces, no vertices.
filter = Gui.Selection.Filter("SELECT Part::Feature SUBELEMENT Edge, SELECT Part::Feature SUBELEMENT Face")
Gui.Selection.addSelectionGate(filter)
Gui.Selection.removeSelectionGate()
- pathfinder
In 3D view.
I'm currently working on a project where I have to put chamfers on literally hundreds of edges and it would really speed up the process. What's also super annoying is that I had to start over selecting the relevant edges like three times now because once I misclick on the background, I lose the edges I selected – not to toot Blenders horn too much here, but in Blender, vertex/face/edge selection can be backstepped with Crtl+Z, which makes it a non-issue over there.
Interesting, how do I use this?TheMarkster wrote: ↑Mon Jan 24, 2022 10:46 pm There is a selection gate.
Now you can only select Edges and Faces, no vertices.Code: Select all
filter = Gui.Selection.Filter("SELECT Part::Feature SUBELEMENT Edge, SELECT Part::Feature SUBELEMENT Face") Gui.Selection.addSelectionGate(filter)
Edit: As a workaround, I decided to create the chamfer first, then add edges after. Works quite well.
- Shalmeneser
You can modify the list of edges after asking for chamfer.
Open the python console and paste into it. Ctrl+Shift+P if you are on a recent 0.20 build, else look in the view menu -> panels.
- pathfinder
Yes, that's what I ended up doing.Shalmeneser wrote: ↑Fri Jan 28, 2022 8:21 pm You can modify the list of edges after asking for chamfer.
Aaaaah, the black magic stuff, gotcha. I'll take a look.TheMarkster wrote: ↑Fri Jan 28, 2022 8:22 pm Open the python console and paste into it. Ctrl+Shift+P if you are on a recent 0.20 build, else look in the view menu -> panels.
Re: [Solved]Options to only being able to select edges/vertices/faces?
You can also use selection observers and add to the selection only certain subobject types on preselection if the Ctrl key is held down. I do this in MeshRemodel with the Auto mode for selecting vertices, for example, many vertices to make a BSpline. But it's not setup to work with edges.
Usage would be:
1) enable auto mode
2) hold Ctrl while mousing over the desired points
3) make the bspline
4) end auto mode
Usage would be:
1) enable auto mode
3) make the bspline
4) end auto mode
