sketch is not fully constrained
transsi
Post by transsi »
What can be the issue
im making same steps in freeecad 0.18 and 0.19.3 and get different results.
create a object and sketch in part design but in 0.19 i get the yello x mark on sketch.
both are done same exact way.
Re: sketch is not fully constrained
This overlay has exactly the meaning you describe: The sketch is not fully constrained. It is normal that new things are included in new versions. This is one of them. Time to upgrade.
Tree View
kisolre
Post by kisolre »
Because 0.19 gives you that extra info. You can work with unconstrained sketches if you want but there will be no guarantee of the proper dimensions. They will not change by themselves but any drag could change them in unexpected way.
There are cases where fully constraining is indeed not needed, e.g. for the length of construction lines, which are used solely to define the center of a mirror, or an outer rectangle used to simulate a boolean "common".
Nevertheless it is good style to fully constrain even those things, just to show yourself that you have thought about everything.
transsi
Post by transsi »
might this be reason why sheet metal workbench fails?
making a pad that is going to be bended according to sketched line.
transsi wrote: Tue Jan 25, 2022 8:37 am might this be reason why sheet metal workbench fails?
I don't think so, but if there are rounding issues involved, you could try to make the line longer.
transsi
Post by transsi »
looks like this is the issue
10:45:34 Traceback (most recent call last):
File "C:\Users\anssi.myllyviita\AppData\Roaming\FreeCAD\Mod\sheetmetal\SheetMetalFoldCmd.py", line 259, in execute
s = smFold(bendR = fp.radius.Value, bendA = fp.angle.Value, flipped = fp.invert, unfold = fp.unfold, kfactor = fp.kfactor, bendlinesketch = fp.BendLine,
File "C:\Users\anssi.myllyviita\AppData\Roaming\FreeCAD\Mod\sheetmetal\SheetMetalFoldCmd.py", line 154, in smFold
solid0 = solid1list[0]
<class 'IndexError'>: list index out of range
transsi
Post by transsi »
this is what i try to do
Näyttökuva 2022-01-25 104814.png (15.87 KiB) Viewed 927 times
transsi
Post by transsi »
and this is how i try to do it
https://www.youtube.com/watch?v=EWvJJwkDq2M
but the yellow x mark is only i thought might have to do something with it.
Upload the file for further investigations.
