sketch is not fully constrained
Re: sketch is not fully constrained
Founded that vidoe guide did not include elevation of bend line. raised it z axle 2mm and boom worked.
seems like i have some issues due the update and unupdated addons.
next trying to get my drawing dimentions work since it gives next errors.
You probably have selected the top of the plate while the line was at the bottom.
Re: sketch is not fully constrained : sheet metal error? or me doing wrong?
Is this issue solved?
I have similar problems with pins to IC circuits. If the pin is 1,5mm (file test01) everything works fine but if you decrease the pin to 1,1 mm (file test02) sheet metal reports: list index out of range. The only difference is that the with is changed between the to models.
Hans
Hans
- test02.FCStd
- with of pin 1,1 mm dont work otherwise identical files
- (17.47 KiB) Downloaded 10 times
- test01.FCStd
- with of pin 1,5 mm works
- (17.5 KiB) Downloaded 10 times
Try a full recompute. That worked for me.
I do not think it is the same problem discussed in this topic.
Gene
- Shalmeneser
Cannot open sketches of test02.
OS: Windows 10 (10.0)
Version: 0.19.23074 (Git)
Hash: 74b866ed3022fd1452c534dae31a721bcc668f2f
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
Locale: French/France (fr_FR)
I will try to upload again.
- test02.FCStd
- (17.47 KiB) Downloaded 7 times
- Shalmeneser
Can open the sketches but cannot fold in 1st test02.
Version: 0.20.26498 (Git)
Python version: 3.8.12
Qt version: 5.12.9
OCC version: 7.5.3
- Shalmeneser
Please do not repost file with the same name.
Yes that's correct.
The only difference between the to files is the with of the pin. 1,5 mm vs 1,1 mm
That gives folding error.
Hans
Hans
- Shalmeneser
The mouse over the fold :
In the rapport view :
List index out of range
File "<string>", line 1, in <module> <class 'NotImplementedError'>: getEditDialog() not implemented
