I will check that out....chrisb wrote: ↑Wed Jan 26, 2022 5:34 pm SheetMetal relies on faces, which can cause problems known from the topological naming problem.
Sheetmetal workbench, Unorientable shape causes error
Re: Sheetmetal workbench, Unorientable shape causes error
It's all as expected - though not desired - considering the topological naming problem. Did you follow the link?
Edit: Crossposted.
Edit: Crossposted.
- Shalmeneser
If you modify the first sketch, you change the number of faces in the following pad and you (perhaps) change the position of the selected face for the folding. It's the Topological_naming_problem.
You can modify the selected face in the 'base Object' Fold Data.
- Shalmeneser
Your first sketch is 'open' : all lines are not really connected : Sketcher_ConstrainCoincident.
You should try :
1) to fully constrain this sketch
2) to draw only 1/4 of the drawing the MultiPattern (symmetry, symmetry)
You should try :
- Capture du 2022-01-26 19-30-01.png (28.14 KiB) Viewed 977 times
More and more I agree with you about what you mention:
For now, for the sake of this (delayed) project, I will try to live with it and refrain form making changes to the underlying pad after folding (or do the foldings again if needed).
Thanks for pointing this all out.
But I assume that this modifying needs more "deep inside knowledge" of Freecad as I understand it. Propably using the Python user i.f., which I am not yet familar with.Shalmeneser wrote: ↑Wed Jan 26, 2022 6:28 pm If you modify the first sketch, you change the number of faces in the following pad and you (perhaps) change the position of the selected face for the folding. It's the Topological_naming_problem.
As pointed out by @Shalmeneser in an earlier post, I tried to do it using Multipattern. Still no positive results yet.
See: Further: as tested with my contribution "Simple shaped with error.FCStd" (see earlier post) the thing is not related to a sketch being non-constrainted.
So I think I can only continue with sketching the whole thing 4 times and do a one-way usage of it (do no change after folding).
- Shalmeneser
1) After MultiTransform, you need to set refine=true to see just one face.
2) You cannot fold heavy thickness.
Wauw, I did that on the smaller/test-design and it works. Thanks.
Next thing I have been working on, and maybe off-topic, is the application of a pattern of holes from another design/file onto this file/design. Is there something like an export/impoert of sketches?
- Shalmeneser
