AdditivePipe along ParametricCurve failing
Miq58
Post by Miq58 »
I am attempting to model a flattened sinoid spring, using the Parametric_Curve_FP macro to generate the spine. Alas, the AdditivePipe always will fail with this error:
2022-01-25 15_06_20-Window.png (13.76 KiB) Viewed 848 times
What am I doing wrong here?
My Freecad version is
OS: Windows 10 Version 2009
Version: 0.20.25645 (Git)
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Federtest.FCStd
(39.59 KiB) Downloaded 19 times
domad
Re: AdditivePipe along ParametricCurve failing
Post by domad »
Miq58 wrote: Tue Jan 25, 2022 2:12 pm ....
Hello, greetings to the community!
Convert the Parametric curve to Sketch (Wb Draft) and transfer it inside the body.
The profile has too large a thickness, this generates intersections in the sweep phase, you can use a thickness of 0.3 mm (keeping 2 mm of height).
Otherwise you have to change the path.
Miq58
Post by Miq58 »
domad wrote: Tue Jan 25, 2022 2:38 pm
Thanks a lot, I see the problem. Is there a way to generate an AdditivePipe with a constant width, ignoring the overlaps? I will need a certain constant width to keep the spring element stable - 0.3mm is much too narrow to stand any force.
I tried the method to convert it to a sketch, but I am getting a fenced structure only, no solid, as I had intended:
2022-01-25 16_29_28-Window.png (155.68 KiB) Viewed 785 times
Miq58
Post by Miq58 »
Wait... Got it better now with a reduced sweeping sketch size. The resulting STL file is HUGE, >57MB. The Cura slicer is able to reduce it again to below 500kB.
Thanks again, I think I can proceed with that now!
GeneFC
Post by GeneFC »
Since the cross section appears to be rectangular you could create a full cycle in sketcher and then pad it to the desired thickness. Then do a Linear Array on the single cycle as many times as wanted.
The sketch will not present any limits on the shape.
Gene
Miq58
Post by Miq58 »
GeneFC wrote: Tue Jan 25, 2022 4:08 pm Since the cross section appears to be rectangular you could create a full cycle in sketcher and then pad it to the desired thickness. Then do a Linear Array on the single cycle as many times as wanted.
Gene
That sounds promising - I will give it a try. Thanks!
domad
Post by domad »
Miq58 wrote: Tue Jan 25, 2022 4:10 pm .......
A somewhat different attempt based on what @GeneFC said.
It can certainly be improved and it is possible to model it to very precise dimensions for any simulations of stresses with the "FEM" Wb.
Federtest.FCStd
(863.04 KiB) Downloaded 15 times
Miq58
Post by Miq58 »
Excellent! This again is worth a try!
