IM still relatively new to freecad and must have done something wrong or missed out a stage because i cant join these parts together.
Every time i try i get a error exclamation and the parts disappear. I have to do crtl+Z to get everything back
Can anyone advise>
Joining Parts
Joining Parts
- Wallet_Pill_Box_005.FCStd
- (232.58 KiB) Downloaded 16 times
Re: Joining Parts
What are you trying to do? Why do they need to be "joined"?
If you want to assemble and animate, for example, you should look into one of the assembly workbenches.
I do not see any glaring problems with what you have done, but it is not clear what you want to do next.
Gene
- Shalmeneser
Re: Joining Parts
* Sketch006 upon DatumPlane004 upon Face6 = Topological_naming_problem
* PartDesign_Clone ?
* You don't need DatumPlanes here
- Shalmeneser
Re: Joining Parts
- Capture du 2022-01-25 21-14-57.png (73.7 KiB) Viewed 524 times
- Wallet_Pill_Box_005_SHALM.FCStd
- (304.79 KiB) Downloaded 11 times
Re: Joining Parts
Your mesh seems has some troubles. Its impossible to convert it into solid.
You should find a nice one or rebuild the hinge with PartDesign...
- Capture.JPG (59.76 KiB) Viewed 515 times
