Dear all,
I would like to ask, whom I have to report missing translations to Slovenian. I am using 0.19.3 version on Windows 10.
In the attachments are marked these places. Some have already been translated in Crowdin for quite some time, some are missing there.
Since limitation, additional screenshots are attached as replies.
Thank you for reply.
Missing translations
Re: Missing translations
Hi and welcome to the forum!
The translation is a community effort. You can create or improve the translations on crowdin at https://crowdin.com/translate/freecad/
We recently discovered a problem with the script that extracted data for CrowdIn, and are in the process of testing the fix for it. While this won't retroactively fix the 0.19.x series, it should be fixed in 0.20.
I am a member of Crowdin and trying to translate as much as possible and most strings there in Slovenian (except for FEM workbench) have been translated. There are some cases that can not be found in Crowdin, like:
- “Create a copy” (first image in previous post)
- “At least two shapes are needed for computing boolean fragments. Got only 1.” (4th image in previous post)
- “Preference system” (5th image in previous post)
- All units categories in dropdown menu (5th image in previous post)
- “Choose orientation” (1st image in this post)
- “Sketch orientation” (1st image in this post)
- “XY-Plane” (1st image in this post)
- “XZ-Plane” (1st image in this post)
- “YZ-Plane” (1st image in this post)
- “Reverse direction” in Sketcher workbench (1st image in this post)
- “Offset:” (1st image in this post)
- “Edit controls” (2nd image)
- “Position” (3rd image)
- “Selection 01” (4th image in this post)
- “Selection 02” (4th image in this post)
- “Control” (4th image in this post)
And here are some other examples where translations in Crowdin have been made, and if I understand correctly, this will probably be corrected in coming versions:
Thank you
Thank you
You could try the script from this post https://forum.freecadweb.org/viewtopic. ... 90#p534494
Read around the post for how to use it.
Maybe something like that could be used to add recent translations to stable versions? Maybe a separate Recent Translations installer?
