[Solved] Changing Angle Value Causes Unsolvable Sketch
PAS_Drafter
Post by PAS_Drafter »
I'm trying to create a master sketch for an Assembly that controls a lever and the motion of the cylinder. I'm drawing up the Master sketch and trying to get the variables to work properly with the sketch, but I'm running into a problem when I change the angel value for 0 to 90. I get an unsolvable error. I've tried moving the reference angle to a number of places but no matter what I do, I seem to get the same thing.
If I start with a 90 degree angle on the lever
I can change it to 45 degrees with no problem
I can then change it to 0 degrees, again with no problem.
However, when I change it back to 90 degree I get the error
Anyone know how I can get around this or what I'm doing wrong?
Thanks
AngleProblem.FCStd
(8.96 KiB) Downloaded 22 times
Re: Changing Angle Value Causes Unsolvable Sketch
I got the same here when changing directly from 90° to 0°.
You did nothing wrong. You can add Advanced solver control in preferences and then check in Sketcher the Sketch size multiplier (or increase the number of iterations.
PAS_Drafter
chrisb wrote: Thu Jan 27, 2022 7:05 am
That solved that problem. Now my stupid Cylinders aren't staying on the right axis as I change degrees. :shock: I'll go back and look at the tutorials and see what I did wrong. I'm pretty sure it is just the way I'm linking them. I haven't done this for a while and I have to go back and remind myself.
Thanks for the help again.
