[Solved] Changing Sketch offset causes Revolve to Disappear
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
I can't figure out what is going on here. I'm trying to draw up a clevis using Pipe and Revolve. I've gotten it to look pretty good for the most part, but I am running into some weird behavior when I try to do the second Revolve.
I create my second Sketch and put in these measurements (particularly the 1.005in offset from center).
I then apply the Revolve command to that sketch. The tool shows that the sketch is revolving around the wrong axis
No big deal here, so I change it to the horizontal axis. However, when I do that, the Revolve disappears
I messed around for an hour trying to find a solution and one of the things I noticed that when I created a new sketch and hadn't put in the Constraints, it showed the part revolving properly. However, once I got everything constrained the way I wanted and I left the Sketcher, The Revolve was now gone. I played around with things a little and out of curiosity I changed the Offset to 1.004in
Not a huge change, but low and behold, when I exited Sketcher, my Revolve was now there.
I can change that offset back to 1.005in and it disappears again.
Any idea why this is happening?
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Re: Changing Sketch offset causes Revolve to Disappear
Here is the file I was working with. For some reason it wouldn't let me attach it to the original post.
- Clevis_Shackle.FCStd
- (156.27 KiB) Downloaded 31 times
Because you had already attached five images which are still files as far as the forum software is concerned.PAS_Drafter wrote: ↑Fri Jan 28, 2022 4:10 am For some reason it wouldn't let me attach it to the original post.
I didn't know there was a limit to the total number of files attached. Good to know. ThanksSyres wrote: ↑Fri Jan 28, 2022 6:02 amBecause you had already attached five images which are still files as far as the forum software is concerned.PAS_Drafter wrote: ↑Fri Jan 28, 2022 4:10 am For some reason it wouldn't let me attach it to the original post.
I don't have a FreeCADable computer currently. Vague guesses are, that you may have double lines in your sketch or that some element have length or radius 0.
I think you may have come across a bug which also resides in 0.20 current master but this is still to be definitely confirmed. In the meantime have a look at the way I'd model it even without knowing about the possible bug in the attached file. Mirrors and Patterns are your friend in the main.
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.19.24267 +99 (Git)
Branch: Branch_0.19.3
Hash: 6530e364184ce05ccff39501e175cf2237e6ee4b
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
- Clevis_Shackle_Syres_019.FCStd
- (220.29 KiB) Downloaded 18 times
Things are here even worse: On a full recompute the first revolve disappears as well.
OS: macOS 10.16
Version: 0.20.27078 (Git)
Python version: 3.9.9
Qt version: 5.12.9
OCC version: 7.5.3
Locale: C/Default (C)
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.3
It is a coplanar issue: make the width of the halfmoons a tiny bit wider and both revolves succeed:
- Clevis_Shackle_cb.FCStd
- (198.42 KiB) Downloaded 16 times
- SnipScreenshot-e2e7e2.png (35.28 KiB) Viewed 1043 times
- Shalmeneser
+1
You should :
* symmetry the revolution
* pocket at the last moment (symmetry through all)
Yep, I had tried both of those suggestions as possible options while I was trying to get this to work and stuff just kept disappearing so I kept looking for ways to make it work in harder ways. It was driving me nuts as I couldn't figure out why it was behaving that way when I thought I was doing it properly. Since I'm just a novice at this, I always assume it is something I am doing wrong.Shalmeneser wrote: ↑Fri Jan 28, 2022 9:48 am+1
You should :
* pocket at the last moment (symmetry trough all)
Thanks for the suggestions.
