How to Use Points on a Face to Base a New Sketch on?
itisyeetimetoday
Post by itisyeetimetoday »
In software like Solidworks, when you create a sketch on a face, I can use the corner of previously extruded body and use that as a point to base all my shapes on my sketch, like I can create a circle that is centered around the corner of an extruded cube. However, how do I do this in FreeCAD?
Syres
Re: How to Use Points on a Face to Base a New Sketch on?
Post by Syres »
itisyeetimetoday wrote: Fri Jan 28, 2022 6:32 am In software like Solidworks, when you create a sketch on a face, I can use the corner of previously extruded body and use that as a point to base all my shapes on my sketch, like I can create a circle that is centered around the corner of an extruded cube. However, how do I do this in FreeCAD?
Using the Attachment Editor as per:
Edit: Explanation of use https://wiki.freecadweb.org/Part_EditAttachment
TheMarkster
Post by TheMarkster »
Take heed there is a well-known bug in FreeCAD known as the topological naming problem.
Grub
Post by Grub »
In your sketch you must extract external geometry with Sketcher External Image
itisyeetimetoday
Grub wrote: Fri Jan 28, 2022 5:58 pm In your sketch you must extract external geometry with Sketcher External Image
Thank you for your response, this is exactly what I am looking for.
