Draft polar array with arbitrary axis
If I create a Draft Polar array, by default, the array is created around the point specified in the dialog (0,0,0 if nothing is changed.
If I an arbitrary line is chosen for the Axis reference in the Properties, the array is now around the end vertex of the line.
Is there a way to have the line be the axis of of the array (i.e. the array radially around the line.)
- DraftPolarArbitrary.FCStd
- (10.95 KiB) Downloaded 13 times
- Snip macro screenshot-4a07cc.png (73.21 KiB) Viewed 995 times
Re: Draft polar array with arbitrary axis
I don't think it's the end of the line, it's the Placement of the line. TheMarkster had a similar topic recently, or at least he was involved (will have a look).
https://forum.freecadweb.org/viewtopic.php?f=3&t=65708
I'm intrigued to merge both topics??
Makes sense. I'd not seen that thread.chrisb wrote: ↑Fri Jan 28, 2022 6:35 pm https://forum.freecadweb.org/viewtopic.php?f=3&t=65708
But, wonders why a Datum line works, but not a basic line? Hmm...
- thomas-neemann
- thomas-neemann
there is a difference if it is a plane or a solid. here is a possibility for a solid and plane
https://www.youtube.com/watch?v=enr2ado-Jso
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.29182 (Git) AppImage
Hash: e89ebba7369dca5775fd8aa878a0d3c494e6b2ac
Python 3.10.5, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Installed mods:
* InventorLoader 1.3.0
* Assembly3 0.11.3
- thomas-neemann
Greetings to the Community!
@drmacro
Once the array has been executed, just align its generation axis to the axis we want (obviously with minimal geometric construction) and then move it along the new axis to the position we want, or vice versa.
@drmacro
... the gif shows how to do it in the file proposed by @drmacro
- DraftPolarArbitrary_domad.FCStd
- (14.56 KiB) Downloaded 5 times
- DraftPolarArbitrary_domad.gif (397.32 KiB) Viewed 261 times
