Imported STEP tree shows root only and cannot be expanded
n8zach
Post by n8zach »
My engineer sent me a complex, multi-part model created in SolidWorks as a STEP file that has the whole tree in it.
While it is opening in FreeCAD I see all the individual objects appearing in the model view, but when it is done I only see the root item.
I do see all the objects rendered in the 3D view but I cannot expand the tree. Is this expected? How can I expand the tree to access individual objects in it?
(When I open it in Fusion360 I do see the tree, so I know it is there.)
OS: macOS 10.15
Version: 0.19.24366 (Git)
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Locale: C/Default (C)
Re: Imported STEP tree shows root only and cannot be expanded
Hi, welcome to the forum!
Please check the Preferences for Import -> Step. Or try Part -> Explode compound.
n8zach
Post by n8zach »
Import Settings didn't seem to change anything, but explode did! Thanks!
TheMarkster
Post by TheMarkster »
Experiment with these 2 checkboxes:
Snip macro screenshot-905c4a.png (77.38 KiB) Viewed 1161 times
Thanks TheMarkster for jumping in. These were the preferences I had in mind (wasn't at the computer, so couldn't check). I think disabling the first is important!
heda
Post by heda »
is it not time to change default to not do the compound merge for v0.20?
this question is quite common...
it is easy to imagine that just about everyone will scratch their head when importing what should be a set of solids and end up with a single one.
imho, better to flip the questions to forum so that it is the ones that want it to be merged that have to ask if there is a setting for that...
heda wrote: Sat Jan 29, 2022 8:29 am is it not time to change default to not do the compound merge for v0.20?
I'm not sure about this, which definitely means that you may be right :) . We had this indeed several times recently. But I see also that many people here use an important Step just as a well built, but still dumb, object; as if it was made with "Create simple copy".
