Make a chamfer on each side of a threaded hole
Hi
Is there anyway I can make a chamfer on each side of a throughall threaded Hole ?
Thanks
Thanks
- chanfrein.PNG (29.8 KiB) Viewed 1051 times
- Shalmeneser
Re: Make a chamfer on each side of a threaded hole
- ChampFrein_SHALM.FCStd
- (82.34 KiB) Downloaded 18 times
- Capture d’écran 2022-02-05 115027.png (36.99 KiB) Viewed 1019 times
hehe... was hoping something more... automagic
Seems you are using Linkstage3 and @Shalmeneser is in master.
Shouldn't make a difference in this case, just noting the difference.
Did you try the chamfer tool? Might work.
At least on one side you could use a countersink.
Yes I did.
And made a chamfer (sketch based) on the other side by referencing the hole's countersink values
- Shalmeneser
Removed thread modeling to reduce file size
OS: Windows 10 Version 2009
Version: 2022.111.28429 (Git)
Branch: LinkStage3
Hash: ec814c42d02f15171f9dbb7f650400c9943abfe0
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: French/France (fr_FR)
Branch: LinkStage3
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
- écrou barillet 1∕2 13UNCx1×2.1∕2.FCStd
- (115.53 KiB) Downloaded 16 times
- Shalmeneser
* The angle 41° is at the wrong place.
* (I would do the hole without chamfer and all the chamfers in the same sketch.)
- Capture d’écran 2022-02-05 132646.png (19.34 KiB) Viewed 880 times
I have the same problem. A easier way to create a sink on both sides of a hole would be great. It is a bit extensive to do so with FreeCAD 0.20.1.
Here is my part. It's a real part, which can be bought. The file is too large, so I uploaded it on DropBox.
https://www.dropbox.com/s/3cir1ixq5w44hxf/MW.FCStd?dl=0
OS: Ubuntu 20.04.5 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.1.29410 (Git) AppImage
Branch: (HEAD detached at 0.20.1)
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Installed mods:
* Curves 0.6.1
* sheetmetal 0.2.57
* Manipulator 1.4.9
* fasteners 0.4.23
