STL to Solid - "Part object is not a shell" error
arhabib
Postby arhabib » Mon May 19, 2014 1:58 am
Hi;
I am new to FreeCAD, trying to convert a 3D mesh in STL format to a solid to do cfd modeling.
First, I created a "part" and tried to convert it to a solid but came up with the following error message:
"Part object is not a shell."
Any help will be appreciated.
Thanks
NormandC
Re: STL to Solid - "Part object is not a shell" error
Postby NormandC » Mon May 19, 2014 3:31 am
To convert a mesh object to a solid, here are the steps:
  1. Switch to the Part workbench
  2. Select the mesh, and go to the Part menu --> Create shape from mesh
  3. Click OK to the dialog
  4. Select the newly created shape
  5. Go to Part --> Convert to solid
  6. Select the newly created solid
  7. Go to Part --> Refine shape
The last step is not necessary, but it will clean the solid of most of its residual edges on planar and cylindrical surfaces.
arhabib
Postby arhabib » Mon May 19, 2014 4:18 pm
Hi;
Thanks for your response.
This is exactly what I do, but still I get the
"cannot convert because shape is not a shell"
error message!
Site Admin
Postby wmayer » Mon May 19, 2014 4:38 pm
After you created the Part object enter this into the Python console:
App.ActiveDocument.ActiveObject.Shape.ShapeType
What does it say then?
NormandC
Postby NormandC » Mon May 19, 2014 4:41 pm
Then it probably means that the mesh does not form a valid enclosed volume (shell).
Switch to the Mesh design workbench, select the mesh object then go to the menu Meshes --> Analyze --> Check solid mesh.
What does it tell you?
Also, can you attach the mesh so we can have a look at it?
arhabib
Postby arhabib » Tue May 20, 2014 4:42 am
Hi again;
It says: "The mesh is not a solid."
Anyways, the STL file is attached.
FYI, this is a dinosaur!
cryptocleidus.zip
(86.12 KiB) Downloaded 296 times
NormandC
Postby NormandC » Tue May 20, 2014 4:50 am
Then the mesh has holes or self-intersecting surfaces and thus cannot be made a solid.
The Mesh design workbench has analysis tools to evaluate a mesh, you could try it.
jmaustpc
Postby jmaustpc » Tue May 20, 2014 6:47 am
The stl file has problems
quick61
Postby quick61 » Tue May 20, 2014 7:18 am
If you look at how the model was made, you'll see why it has problems. I converted it to a shape and them used transparency on it to reveal the fact that the fins were just "stuck into" the body. Not the way to model such a critter. Espicialy if you intend to do anything with it after it is modeled. You might be better off modeling a new one from scratch and doing it right.
Mark
OS: Kubuntu 14.04 LTS
Platform: 64-bit
Version: 0.14.3624 (Git)
Hash: 581d88485dfab42292cdec63a6e0d34a216d772c
Python version: 2.7.6
Qt version: 4.8.6
SoQt version: 1.6.0a
OCC version: 6.7.1
jmaustpc
Postby jmaustpc » Tue May 20, 2014 7:25 am
If he has them as separate "blobs" in some application somewhere...maybe a work around might be to export the body and fins as independent stl files, then "import" them into a single FreeCAD document as 5 separate stl files, convert them independently to solids and then use Part Boolean Fuse to make one solid?
A fuse of the stl file might work, but stl Booleans often give problematic results. So I would think you would be best to convert them to solid shapes first.
