Issue #6767- [Bug] Draft big Scale Multiplier with 2d text causes crash (was: Freecad and really big dimension)
m1cha1
Post by m1cha1 »
I'm experimenting with Freecad and I've found some problems (problem with displaying or crashing) with big dimension
Problem with displaying-step to reproduce (Part workbench)
1. Insert Cube
2. Change dimension for example Length by adding 0 to the default size (10mm)
From 100000000 mm there are problem with displaying cube, from 1000000000 mm it completely dissapear. If you increase size more there are problems wilth lengths in Python console for example :FreeCAD.getDocument('Unnamed').getObject('Box').Length = '99999999999999991611392.00 mm'
Crash-step to reproduce (Draft workbench)
1. Create Text (for example "HELLO")
2. Change properties Display mode: 2D text
3. Change Scale Multiplier to 10000- you should get Access violation
4. Increase Scale Multiplier to 1000000 or more you should get crash
Maybe it will be better when the user will get some warning or maybe it's possible to prevent crash.
BTW I've checked also Fusion360 when you increase the size of the cube you will get crash (without warning). So probably it's a general problem of the CAD software.
OS: Windows 10 (10.0)
Version: 0.20.28671 (Git)
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Test file:
crash.FCStd
(7.68 KiB) Downloaded 15 times
Open file and change Scale Multiplier by adding 0 after 1 till crash (10, 100, 1000...)
Re: Freecad and really big dimension
These are basic issues with floating point numbers and their finite representation in computers.
thomas-neemann
Post by thomas-neemann »
m1cha1 wrote: Fri Apr 15, 2022 10:42 pm .... 1000000000 mm it completely dissapear. ....
this seems to be a windows problem. here under linux it works
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.28697 (Git) AppImage
Branch: (HEAD detached at 37ed6fb)
Hash: 37ed6fb92e2d336be0d934530cabc1e5eb815e0a
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
m1cha1
Post by m1cha1 »
thomas-neemann wrote: Sat Apr 16, 2022 7:04 am this seems to be a windows problem. here under linux it works
Thank you for checking. So it's not so obvious. Could you please also test draft Scale Multiplier problem.
thomas-neemann
I can confirm that in master, there is no crash in realthunder, but you can no longer represent it in a meaningful way. what is this needed for?
m1cha1
Post by m1cha1 »
thomas-neemann wrote: Tue Apr 19, 2022 8:11 am I can confirm that in master, there is no crash in realthunder, but you can no longer represent it in a meaningful way. what is this needed for?
Thank you very much for confirmation. I just want to make a bug report:
https://github.com/FreeCAD/FreeCAD/issues/6767
thomas-neemann
m1cha1 wrote: Tue Apr 19, 2022 8:42 am ...I just want to make a bug report:
what's the point of creating a bug report for something that isn't needed?
m1cha1
Post by m1cha1 »
thomas-neemann wrote: Tue Apr 19, 2022 8:45 am what's the point of creating a bug report for something that isn't needed?
Maybe it's not needed, maybe it's not a standard situation, maybe nobody repair this. But the crash in my opinion it's not acceptable.
thomas-neemann
m1cha1 wrote: Tue Apr 19, 2022 8:58 am
In my opinion, there are more important construction sites in freecad. e.g. techdraw
Even if there are more important things to fix, it should be reported if FreeCAD crashes. The tickets are not a wish list what to tackle first.
