Sketcher
Sketcher
When I start a new project in part design, it all goes well until I select a tool. When I do it goes from red to ghost, but then will not draw in the sketch. I have tried line, circle, etc. All perform the same. When I try to close, it tells me I am in edit mode and will not let me out until I close the task. I know I must be doing something wrong, but cannot identify what it is. HELP!
Re: Sketcher
Please read the topic "IMPORTANT: Please read first before asking for help " before asking for help.
It explains how to include useful information to troubleclear your issue.
Enrico
Enrico
Re: Sketcher
Sorry bout that....first post. I read it but posted without the info.
OS: Windows
Platform: 32-bit
Version: 0.14.3389
Python version: 2.6.2
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.5.1
OS: Windows
Platform: 32-bit
Version: 0.14.3389
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.5.1
Re: Sketcher
You may have a look at the sketcher tutorial: http://www.freecadweb.org/wiki/index.ph ... r_Tutorial
It goes through all steps in order to make a sketch.
Ulrich
Ulrich
Re: Sketcher
Ulrich,
Thanks for the thought. However, I watched that tutorial (and several others) several times. It just does not allow me to sketch a shape. The tool(s) start off red, ghost when selected but will not sketch, just stays in edit mode until I close it.
Re: Sketcher
The Geometry tools are not red, those are the Constraints, the Geometry tools are white.
Here are the Sketcher Constraint tools - http://www.freecadweb.org/wiki/index.ph ... Menu_Icons
and here are the Sketcher Geometry tools - http://www.freecadweb.org/wiki/index.ph ... Menu_Icons
You can not draw anything with the "red" constraint tools. If your not seeing the Sketcher Geometry tools, they are probably hidden under a pulldown or turned off in View > Toolbars
Mark
Mark
Re: Sketcher
Mark,
Thanks. I understand the tools are white, but I meant that they have "red" points on the ends what ghost when selected.
Re: Sketcher
Please go to Edit --> Preferences / General / Output window, and tick both "Redirect internal Python output to report view" and "Redirect internal Python errors to report view".
Then make sure the Report view is visible by going to the View --> Views menu.
Try again to create a new sketch, then click on a sketch tool and tell us if you see an error message in the Report view (text box at lower left).
Re: Sketcher
You cannot close a FreeCAD document or the program if you are in sketch edit mode, you need to exit from the Task panel. That's normal behavior.mytwinbud wrote:When I try to close, it tells me I am in edit mode and will not let me out until I close the task.
Re: Sketcher
normandc,
I just went throught all of those steps. There is no error message in the report view window when I select the tool. (or attempt to use it. If I right click, the tools become active again. Then when selected they ghost again, but will still not allow the sketcher to work.???
