[ Bug ] Sketcher: Problem with Grid size preference
Roy_043
Post by Roy_043 »
There is a problem with the Sketcher Grid size preference in V0.20:
  1. Start FreeCAD without user.cfg.
  2. Activate the Sketcher WB.
  3. Call Std_DlgPreferences.
  4. Change the Sketcher Grid size preference to 20 mm.
  5. Press OK.
  6. Start a new document.
  7. Start a new sketch.
  8. Close the sketch.
  9. Check the Grid Size property of the sketch.
  10. Result: 10 mm.
The problem does not occur in V0.19: there the Grid Size property of the sketch is 20 mm.
And in V0.20 the problem persists even after a restart.
OS: Windows 8.1 (6.3)
Version: 0.20.28857 (Git)
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Installed mods:
Roy_043
Re: [ Bug ] Sketcher: Problem with Grid size preference
Post by Roy_043 »
Confirmed:
https://forum.freecadweb.org/viewtopic.php?f=3&t=68724
Issue:
https://github.com/FreeCAD/FreeCAD/issues/6890
Maybe this should be labeled for V0.20? But I do not know how to do that.
openBrain
Post by openBrain »
As there seems to have several issue with saving quantity values, I wonder if this can be due to git commit 8b33a70513.
Will try to investigate later.
Ping @wmayer
Roy_043
Post by Roy_043 »
I noticed a "GridSize_History" group is created for this preference. Why is that?
openBrain
Post by openBrain »
Roy_043 wrote: Mon May 16, 2022 6:55 am I noticed a "GridSize_History" group is created for this preference. Why is that?
IIRC, with PrefQuantitySpinBox, you get a short history when you right-click the box so you can reset easily to a former value. ;)
Roy_043
Post by Roy_043 »
Thanks, yes it does work that way.
Founder
Post by wmayer »
openBrain wrote: Mon May 16, 2022 6:44 am I wonder if this can be due to git commit 8b33a70513.
Yes, it's caused by this change. However, the PrefQuantitySpinBox did it wrong all the time because it didn't use the actually set entry name but used Hist0. If you look at the .ui file you will see that the name is GridSize but in the code Hist0 was used.
git commit 57fcdd8182
Roy_043
Post by Roy_043 »
Thanks for the fix.
