cannot add a window from menu or parts lib
Roy_043
Re: cannot add a window from menu or parts lib
Post by Roy_043 »
Can it be that you lack experience with the Arch Workbench?
The mentioned files will create a hole in the wall, but indeed do not resize.
Try this file instead:
parts_library\Architectural Parts\Windows\Fixed\Window with 2 vertical fixed glass.FCStd
See the attached animation.
65pony wrote: Fri May 20, 2022 6:31 pm is there a newer version of the libraries that are compatible with 0.19 and 0.20?
No, I obviously would have already mentioned this if that were the case.
65pony wrote: Fri May 20, 2022 6:31 pm can older library file be modified to work wit the newer version?
Anything is possible. But since the files are inconsistent it would not make a lot of sense to attempt this IMO.
65pony
Post by 65pony »
Hello:
My apologies, all my fault, I got it all working now. After I started the version 0.20, I reset all the preferences to the manufacturer setting, uploaded all the work benches again along with the libraries. Now I can install windows, doors and change their dimensions.
thanks for the help
