(WORKAROUND) Sketcher limit?
thomas-neemann
Re: Sketcher limit?
Post by thomas-neemann »
thomas-neemann wrote: Wed May 18, 2022 11:00 am ..
file
edit
final version
539-ok.FCStd
(17.36 KiB) Downloaded 11 times
Last edited by thomas-neemann on Thu May 19, 2022 4:04 am, edited 2 times in total.
thomas-neemann
Re: Sketcher limit?
Shalmeneser wrote: Wed May 18, 2022 10:00 am ..
Do you really need a circle ? a line is not enough ?
in this case it is sufficiently accurate (1,5 mm). I was able to measure it with reathunder
edit
final version
Last edited by thomas-neemann on Thu May 19, 2022 4:04 am, edited 1 time in total.
bambuko
Re: Sketcher limit?
Post by bambuko »
Shalmeneser wrote: Wed May 18, 2022 11:03 am ...Don't understand, the vertical constraint is needed.
yes, but at the right moment...
There are more than one solutions in sketcher in this case
The way vertical constraint was applied prevented correct/desired solution
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
bambuko
Re: Sketcher limit?
Post by bambuko »
thomas-neemann wrote: Wed May 18, 2022 11:03 am ...can you upload the file?
I am about to depart on a long journey :)
if it is still needed I will try to find the time over weekend
thomas-neemann
Re: Sketcher limit?
bambuko wrote: Wed May 18, 2022 12:18 pm ...
there is no hurry, thank you
Roy_043
Re: (WORKAROUND) Sketcher limit?
Post by Roy_043 »
Thomas's original thought seems to be correct. The model is beyond the limits of what the solver can handle. If you scale everything down (m->mm) the problem does not occur.
1054-scaled-down.FCStd
(8.56 KiB) Downloaded 9 times
thomas-neemann
Roy_043 wrote: Wed May 18, 2022 1:24 pm ..
Thanks for the cooperation, I think it's a good workaround
