(WORKAROUND) Sketcher limit?
- thomas-neemann
I can't set a constraint when building inclined railroad tracks in a curve. Am I exceeding a limit in Sketcher?
these dimensions
should be 213mm
when i try i get this result
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.28873 (Git) AppImage
Branch: (HEAD detached at 4366c2f)
Hash: 4366c2faecae2c5326c12bbe8cbd230ec817eb0c
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
these dimensions
should be 213mm
Last edited by thomas-neemann on Wed May 18, 2022 11:03 am, edited 1 time in total.
Re: Sketcher limit?
You are not showing the whole picture of your file (and the reason for your problem) ...
get rid of the vertical constraint and you will stop confusing FreeCAD
- thomas-neemann
- thomas-neemann
Re: Sketcher limit?
a task can be the problem ?
- Shalmeneser
Re: Sketcher limit?
50m & 0.2m -> R=6250m
6250 / 0.2 = 31250
The radius will be around 31250 times the small dimension.
Do you really need a circle ? a line is not enough ?
(the circle is the straigth upper line.)
6250 / 0.2 = 31250
- Annotation 2022-05-18 115618.jpg (19.71 KiB) Viewed 703 times
- DimensionsCircleLine_SHALM.FCStd
- (5.42 KiB) Downloaded 16 times
- thomas-neemann
Re: Sketcher limit?
thanks for the tip, will test it and measure the difference in track lengthShalmeneser wrote: ↑Wed May 18, 2022 10:00 am ..
Re: Sketcher limit?
actually in rail engineering it's neither straight line nor the circle, search:Shalmeneser wrote: ↑Wed May 18, 2022 10:00 am ...Do you really need a circle ? a line is not enough ?
https://duckduckgo.com/?q=rail+transiti ... 7-1&ia=web
and yes... it matters (even in railway scale models)
In Thomas's case if he insist on circle it is easily done, as I have shown.
- thomas-neemann
Re: Sketcher limit?
I can't measure the difference because fcinfo drops out for me. here is a workaraund in draft from min 0:37Shalmeneser wrote: ↑Wed May 18, 2022 10:00 am ..
edit final version
https://www.youtube.com/watch?v=HbFAzExyqk4
Last edited by thomas-neemann on Thu May 19, 2022 4:14 am, edited 2 times in total.
- Shalmeneser
Re: Sketcher limit?
Don't understand, the vertical constraint is needed.
- thomas-neemann
Re: Sketcher limit?
can you upload the file?
