New to CAD so correct me if the terms I'm using aren't clear. I work in a lab and unfortunately the entire CAD model of our system got saved as STL files and then the source STEP files were lost. I have been remodeling everything using the STL files as a base. I am not only trying to reconstruct the shape geometry, but the relative positions as well. The general method was to generate a points object from the mesh, plug it into a new object using a shapebinder, and then build the solid off of that.
Many of the components are identical except for their relative placement. For those with the same orientation, it was simple enough to write a short python macro that would make a copy and transform it using the difference of the first vertex of the original mesh (the one I rebuilt) and the first vertex of the target mesh (another STL file of the same object.) However, there are some objects that are not only significantly more complicated in their geometry (thus making it time consuming to rebuild the same thing many times) but also have different orientations.
Is there a way to generate a transformation based off a point or face mapping? Say, if I have four points on the original mesh that I ultimately want to end up at four points on the target mesh, **provided these are actually congruent (no shear or stretching) and form a linearly independent basis, can I get FreeCAD to generate that transformation?
I have tried generating the matrix representation of the **affine transformation based on the four initial vectors and the four target vectors and simply plugging it in using copy.Placement.Matrix = affine_transform_matrix but this didn't work.
I'm also open to a radically different approach, I just want to understand how I can use a point mapping to generate an **affine transformation.
I attached an example file, I want to make a copy of the SilicaGasket-1 solid and map it onto the mesh labeled SilicaGasket-2.
Thank you in advance. While I would like to solve this particular example, I am very curious about how to do something like this in general. I reckon it could make for a pretty useful macro.
*NOTE: I am really talking about a subset of affine transformations, I understand that FreeCAD can not simply deform a parametric solid with stretching or shearing, I mean only angle-preserving transformations, limited to rotations and translations
Transformations Based on Point Mapping
- PointMapTransformationExample.FCStd
- (183.24 KiB) Downloaded 18 times
- Shalmeneser
Re: Transformations Based on Point Mapping
An assembly wb can position parts relatively with other parts.
- PointMapTransformationExample_SHALM.FCStd
- (32.75 KiB) Downloaded 12 times
Depending how accurate the position should be you could use open3d. If you want to be compatible with freecad 0.19 the latest version you could use is 0.10 (because of numpy dependecies). You could use global registration first and afterwards fine align with ICP registration (Maybe ICP is enough for your purposes as well).
There are also good examples how to do this on the site. No need for point clicking.
This is working with point clouds only. So therefore you have to sample point clouds from the stl files, and also sample a point cloud from your newly generated CAD model. What you get is the transformation matrix which you can attach to the CAD model via placement. You can also calculate the point cloud distances to get an idea about which accuracy can be achieved.
Rigid transformations are implemented in FreeCAD as Placements. If you have congruent corresponding triangles in your mesh pairs you can calculate the placement required to transform one into the other. Enclosed I've done it with two Sketcher triangles, but the math would be the same for other objects. Select (ctrl-click) the vertices of the first triangle, then the corresponding vertices of the second and run the macro.
def placetriangleXY(points):
''' given three triangle vertices find the placement that
Places points[0] at the origin
Places points[1] on the x -axis
Puts the triangle on the XY-plane
return App.Placement(-points[0], App.Rotation(points[1]-points[0], App.Vector(),(points[2]-points[0]).cross(points[1] - points[0])).inverted(), points[0])
def selectTriangles():
''' select the congruent triangle vertices in the same order
returns the global vertex locations of the two triangles in the order selected'''
pointslist=[]
sels = Gui.Selection.getSelectionEx()
for sel in sels:
points = [v.Point for v in sel.SubObjects]
pointslist.append(points)
return pointslist
t0, t1 = selectTriangles()
p0 = placetriangleXY(t0)
p1 = placetriangleXY(t1)
#move sketch1 onto sketch0
sk1 = App.ActiveDocument.Sketch001
newPlacement = p0.inverse() * p1 * sk1.Placement
sk1.Placement = newPlacement
- maptriangles.FCStd
- (5.56 KiB) Downloaded 11 times
Yep, that's it, thank you. The methods I was attempting to generate the placement matrix were a far cry from the elegance you've got there, I'll have to study it for a while. Cheers!
This, perhaps, is more robust. I forgot the optional priority argument in App.Rotation, but the default seems to work.inthereeds wrote: ↑Wed May 18, 2022 10:55 pm Yep, that's it, thank you. The methods I was attempting to generate the placement matrix were a far cry from the elegance you've got there, I'll have to study it for a while. Cheers!
return App.Placement(-points[0], App.Rotation(points[1]-points[0], App.Vector(),(points[2]-points[0]).cross(points[1] - points[0]), 'XZY').inverted(), points[0])
pointslist=[]
for sel in sels:
return pointslist
