Hello!
Why are the endpoints of the segments not visible in Sketcher? Also, single points on the sketch are not visible.
Points aren't visible in Sketcher
- 2022-05-18_23-39-06.png (494.05 KiB) Viewed 1080 times
- Shalmeneser
Re: Points aren't visible in Sketcher
Points are in construction mode by default (like blue line).
To see point outside a sketch, you need to change this mode : Sketcher_ToggleConstruction
I don't need to see points outside of sketch. I can't see it inside of sketch. Did you see my screenshot? Endpoints of the arc are not visible.Shalmeneser wrote: ↑Wed May 18, 2022 5:52 pm Points are in construction mode by default (like blue line).
Is this property correctly set?
- vertex.png (72.73 KiB) Viewed 990 times
- Shalmeneser
Segment OR arc ?
I created a new file and there the points were displayed. Now I have saved these settings of 11 pixels per point and in the old file where points were not visible before, now they have appeared. Thank you!
- 2022-05-19_15-07-27.png (484.04 KiB) Viewed 933 times
Sorry, I didn't express myself clearly enough. Both.
