Copy constraints when merging sketches
llll
Post by llll »
Hi, hello all.
Had to separate sketch into two parts due to solve times being +15secs for every alteration.
Now when combining two sketches, it appears all constraints are gone. The Sketcher_Validate tool does some of the coincidents automatically but that is 2-300 short of total.
How to copy all constraints into the merged sketches? I have no clue (as usual ;)
What's the process to solve this issue?
Thanks
Edit:
Shalmeneser wrote: Thu May 19, 2022 5:21 am The more you explain and give details, the more we have a chance to understand your question and have an answer.
Separated 1 sketch.. into 2 sketches.. they are separated by ideas as you suggest.. too many constraints were causing lag.. @ChrisB book says over 100 constraints per sketch is not recommended...
Merging with Sketcher_MergeSketches causes loss of all constraints contained in source sketches.
To even open the merged sketch you need at least some coincidences which are added automatically after this popup, by the Sketch_ValidateSketch tool
Shalmeneser
Re: Copy constraints when merging sketches
Post by Shalmeneser »
llll wrote: Thu May 19, 2022 12:51 am 1) Had to separate sketch into two parts due to solve times being +15secs for every alteration.
2)Now when combining two sketches, it appears all constraints are gone.
3) The Sketcher_Validate tool does some of the coincidents automatically but that is 2-300 short of total.
4) How to copy all constraints into the merged sketches? I have no clue (as usual ;)
5) What's the process to solve this issue?
1) Imho, it's not the sketch but the downward operations which take time.
2) Combining : which tool ? Explain clearly how do you separate then combine.
3) Sketcher_ValidateSketch is for exceptionnal errors, not for all your constraints.
4) Ctrl+C, Ctrl+V, suppress lines in each sketches.
5) KISS : keep it stupidly simple. One sketch = one logical idea. Separate idea and functions in different actions.
llll
Post by llll »
Shalmeneser wrote: Thu May 19, 2022 5:21 am Ctrl+C, Ctrl+V, suppress lines in each sketches.
What do you mean by suppress?
It is only a sketch at this stage.
I am using the stable Link Branch on windows, but do not see this option when right clicking the tree
Shalmeneser
If your aim is to minimize your sketch, why do you merge 2 sketches ?
1) Duplicate the big sketch
2) Open each sketches then suppress [SUPPR] the duplicated lines. (One (only) sketch can refer to the other via external geometry)
drmacro
Post by drmacro »
Multiple, simple sketches are far better.
The fact that you are discussing this indicates to me your sketch is too complicated and should be broken up, possibly into far more than two sketches.
Shalmeneser
Do you dream of a file ? impossible with OP.
A good start would be to explain what you finally want to have as a model. Are there any images to link?
drmacro
Post by drmacro »
Shalmeneser wrote: Thu May 19, 2022 9:54 am Do you dream of a file ? impossible with OP.
What? Is your crystal ball not working? :mrgreen:
adrianinsaval
Post by adrianinsaval »
to be expected, crystal ball techs are scammers, sent mine for repair months ago and still haven't got it back :roll:
llll wrote: Thu May 19, 2022 12:51 am Separated 1 sketch.. into 2 sketches.. they are separated by ideas as you suggest.. too many constraints were causing lag.. @ChrisB book says over 100 constraints per sketch is not recommended...
So you know you shouldn't make overcomplicated sketches, then why are you trying to merge them? Keep them separate.
thomas-neemann
Post by thomas-neemann »
llll wrote: Thu May 19, 2022 12:51 am ...
is that a solution (coarboncopy)?
https://www.youtube.com/watch?v=YVWNpu-KDEo
phpBB [video]
