Questions about array holes, please help
- xsuper9988
Because projects usually have a lot of combined array holes
The point is that I need to have these holes all controlled by variables
When my first block is finished
But there is no way to copy to other blocks
I mean "LinearPattern", "PolarPattern", "MultiTransform"...etc
There is no way like "body objects", "sketches"...etc can be copied directly
And these can continue to refer to the original "spreadsheet" after copying
It wastes a lot of time to do it all over again
I would like to ask if there is any other method that can be used?
For example, is there a way to draw these variable-controlled numbers of "array holes" within a "sketch"?
- ArrayHoleSample.FCStd
- (45.05 KiB) Downloaded 19 times
- SamplePIC.png (153.21 KiB) Viewed 945 times
- Q01.png (144.67 KiB) Viewed 945 times
- Q02.png (119.13 KiB) Viewed 945 times
- COPY.png (137.08 KiB) Viewed 945 times
- Shalmeneser
Re: Questions about array holes, please help
* A sketch cannot change its number of line
* Only a (Linear/Polar) pattern can change numbers of action
(File : bad idea with boolean intersection)
(btw, use just LinearPattern)
- ArrayHoleSample_SHALM.FCStd
- (55.75 KiB) Downloaded 13 times
- xsuper9988
From your reply I just discovered the boolean logic of "Common"Shalmeneser wrote: ↑Thu May 19, 2022 9:52 am * A sketch cannot change its number of line
This method can be done successfully
Although the result was not what I expected
But this method is very interesting
thank you very much for your reply
Hope someone can suggest more ways
By 'copy', do you mean to have an instance that has some variation of some parameters from the original design? Are you looking for something like configuration table kind of thing? Just read through the posts and see if this is what you want.
- xsuper9988
Sorry I may not have been detailed enoughrealthunder wrote: ↑Fri May 20, 2022 1:30 am By 'copy', do you mean to have an instance that has some variation of some parameters from the original design? Are you looking for something like configuration table kind of thing? Just read through the posts and see if this is what you want.
Additional details
Usually "MultiTransform" will contain "LinearPattern", "PolarPattern"...etc
Then the parameters in "LinearPattern" also use "spreadsheet" ("Q02.png")
"MultiTransform" and "MultiTransform1" in "Q01.png" are the same
But "MultiTransform" cannot be copied directly to "MultiTransform1"
To generate "MultiTransform1" need to re-create one by one
This is very inefficient and takes a lot of time
In the example "MultiTransform" has only one Pattern (LinearPattern)
It takes more time when there is more than one pattern
Because Shalmeneser said "Sketch" cannot variably increase the number of circlesShalmeneser wrote: ↑Thu May 19, 2022 9:52 am * A sketch cannot change its number of line
Seems like only create function "MultiTransform can directly copy and paste"
Like "Sketch", "Object Body" copy and paste
After copying it is still controlled by "spreadsheet"
I don't know if it will be difficult to implement this function
I might consider the Draft Point array for such a thing or Lattice2 workbench with single custom placements.
- xsuper9988
- papyblaise
you have to do the ArrayHole from Pocket
- ArrayHole.FCStd
- (24.63 KiB) Downloaded 10 times
- ArrayHole.JPG (34.72 KiB) Viewed 674 times
- xsuper9988
Isn't that the example I uploaded?
Your example still looks the same
And most importantly, "MultiTransform" cannot be copied and pasted to "MultiTransform1"
