Is it possible to adjust the colors and contrast of the navicube?
I can see the cube, but the faces are the same color as the text...
Navicube contrast/colors
- adrianinsaval
Re: Navicube contrast/colors
cube menu addon had some color change options IIRC, if the addon is not working anymore you can look at it's code and find the parameters that can be then edited in freecad
Cube menu doesn't seem to have anything...unless it just doesn't work.adrianinsaval wrote: ↑Thu May 19, 2022 1:53 pm cube menu addon had some color change options IIRC, if the addon is not working anymore you can look at it's code and find the parameters that can be then edited in freecad
Looking a NaviCube.cpp the colors can be changed by parameters.
But, I'm not clear on how to convert any color number scheme I'm familiar with to a 10 digit unsigned...
Side note: adding the parameters TextColor and FrontColor seem to be handled fine on a vanilla Debian Bullseye with Xfce, but on a Raspberry Pi with Bullseye and GTK+3 it changes the corners colors only. And in the later, messing with those values too much causes a segfault crash...
