I need to seep or loft between 2 objects
but I need the transition rate to be no linear
For exmaple, imagine the image attached was a loft
It transitions between the to faces at a no linear rate
I need to do it with some complex shapes
Sweep/Loft With non linear transition rate
- 屏幕截图(2).png (367.97 KiB) Viewed 546 times
- papyblaise
Re: Sweep/Loft With non linear transition rate
for this kind of shape it is better to make a trapezium with a curved side and "Revolution"
you can vary l1 , l2 , h , and R
this flow will be suitable for Schml: there are only 4 lines
- toupie.JPG (24.99 KiB) Viewed 526 times
- toupie.FCStd
- (12.41 KiB) Downloaded 10 times
I dont want to do it with circles
it is just an exmaple to explain what i want
I want to do it with 2 complex shapes
for example
here is a sweep with a curved path
butin the picture only the left side edge is what i want
i want all the sweep walls to be curves oriented the same respective to the center
a non linear transition rate is the easiest way i think
- 屏幕截图(4).png (449.64 KiB) Viewed 490 times
You can have intermediate sections controlling the transition from one end to the other.
