can some one help punching holes in a circle?
Workshop_Notes
Re: can some one help punching holes in a circle?
Post by Workshop_Notes »
papyblaise wrote: Fri May 20, 2022 9:47 am Funny same idea as Schlm but with straight lines
Both ideas are clever, but are they smart? If you had to put 40 holes through a ring, how long would it take to draw the path linking them together?
Is there a good way of solving this as a general class of problem rather than a specific instance with a small number of symmetrical holes?
If they are good general solutions, we could generate a list of 25 random numbers between 0 and 360 and the time/effort taken to produce the finished model should not be affected.
Workshop_Notes wrote: Fri May 20, 2022 12:23 pm Both ideas are clever, but are they smart? If you had to put 40 holes through a ring, how long would it take to draw the path linking them together?
The EdWilliams way is. For a big number of holes you should put the data in a table and use a very small Python script to rotate the sketches, or you would even go directly for subtractive cylinders (don't use them currently in Patterns!).
papyblaise
Post by papyblaise »
I'm not good at programming a multiple variable array where the number of occurrences is random, and the step is random, is this programmable?
with if and or so, then etc.....
drmacro
Post by drmacro »
Just as another option. No programming.
Peek 2022-05-20 11-27.gif (176.28 KiB) Viewed 325 times
Example-Lattice2-Spreadsheet-2.FCStd
(61.09 KiB) Downloaded 9 times
edwilliams16
Post by edwilliams16 »
Lattice2 with a polar array driven by a list from a spreadsheet was what came to me first - but for the OP that was clearly overkill when I only had to place two pockets. It was also driven by the initial sketch data dimensions, requiring no trig. I think it would be simpler, but less elegant, to use the Part workbench with Lattice2 - which you likely agree with.
edwilliams16
It is more straightforward using the Part Workbench with Lattice2
Screen Shot 2022-05-20 at 11.21.54 AM.png (56.47 KiB) Viewed 255 times
Just plug the angles into the Polar Array values property.
Example-Lattice2-Spreadsheet-EW2.FCStd
(42.1 KiB) Downloaded 7 times
