Function like Fillet/Chamfer for Undercuts
I'm trying to find a function to perform an edge feature, similar to fillet or chamfer, but which does an undercut instead. Undercuts are a common design feature when a turned surface is intended to be a positioning surface for assemblies, to ensure faces are flush and no interference from leftover material from tool tip radius on cutting inserts.
Attached is the part model, where the feature "Chamfer" was created (somewhat white in this image), but which should be replaced by the undercut (indicated in black on this blowup of the sketch). I noticed that the chamfer function allows the possibility of specifying 2 values. I would be looking for the "Undercut" function to allow specifying (1) the depth from the face to the bottom of the arc, and (2) the angle of the tangential undercut from the central axis (standard options of 60 degrees or 45 degrees).
I didn't think it would be necessary to specify that as part of the sketch for the revolved section.
Can anyone point me to where I could find that undercut function?
- TestPart_Blisk_01.FCStd
- (73.21 KiB) Downloaded 18 times
Re: Function like Fillet/Chamfer for Undercuts
There is no dedicated undercut feature or dressup. In this case you have to make a Groove or include it in the sketch - similar to what would be done when creating it on a lathe.
- papyblaise
In the sketch of the profile you include the negative angle
- congé.FCStd
- (18.36 KiB) Downloaded 16 times
- cougé.JPG (14.04 KiB) Viewed 1214 times
Trying to take a stab at "retrofitting" the PartDesign Chamfer code to offer the additional option for Undercuts.
I located "TaskChamferParameters.cpp".
That led me to "FeatureChamfer.cpp".
This last identified the need for "mkChamfer.AddDA" ... which I cannot find.
I searched all FreeCAD projects on GitHub repository, but I am unable to locate the reference to that class/function's source code.
I even checked using https://dev.opencascade.org/search to see if that was an OCCT class/function but it did not identify any relevant files.
Changes that I planned to make are high-lighted in the attached with the string "##EAJM".
Can you please indicate where I could find that?
After further digging, I found reference to "BRepFilletAPI_MakeChamfer.hxx" in "PreCompiled.h".
But that is pointing to another reference "OpenCascadeAll.h", which presumably implies "OpenCascadeAll.cpp", but I cannot locate the actual code for either those, under the FreeCAD repositories on GitHub.
If that is OCCT code, I would have expected that FreeCAD would have its own image of that code (at least as a failsafe if OCCT disappeared), although with restricted access, so that the community would have visibility of, and be working from, the same non-FreeCAD reference base code, while allowing community members to offer ideas/suggestions on coding tweaks, while allowing the gurus to control the sanity and implementation of those tweaks on a FreeCAD-custom extension to OCCT, which could then be fed upstream to OCCT for consideration in their core code (a bit like Ubuntu managing its image relative to the Debian distro). That might allow FreeCAD to move ahead on things even when OCCT is refusing to incorporate those but, at the same time, keeping those changes distinct from the base FreeCAD code to hightlight that they belong elsewhere. Just a thought.
Thank you for responding, chrisb.
Incorporating a tweak in the Chamfer function seems more logical, because that would have removed the tedium and complexity of creating a sketch, replacing that with a selection of a profile "cases" with associated parameters. That would have been more in line with what I was expecting from a standpoint of intuitive GUI and ease of functionality.
I acknowledge the power and flexibility of Groove, since it uses a task-specific sketch. I also looked at trying to identify the sketch constraints that I have to "suspend", in order to modify the existing sketch.
OS: Ubuntu 20.04.4 LTS (MATE/mate)
Version: 0.20.28611 (Git) AppImage
Branch: (HEAD detached at a3b804e)
Hash: a3b804e7806c2b3b5e1228c41bca4569a743b400
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Installed mods:
* workfeature
* Curves 0.3.0
* offline-documentation 1.0.0-alpha
* workfeature-macro
* Pyramids-and-Polyhedrons
Actually adding the dressup things like the under cut is best done in the sketch.eajmarceau wrote: ↑Sat May 21, 2022 9:57 pmI acknowledge the power and flexibility of Groove, since it uses a task-specific sketch. I also looked at trying to identify the sketch constraints that I have to "suspend", in order to modify the existing sketch.
OS: Ubuntu 20.04.4 LTS (MATE/mate) Word size of FreeCAD: 64-bit Version: 0.20.28611 (Git) AppImage Build type: Release Branch: (HEAD detached at a3b804e) Hash: a3b804e7806c2b3b5e1228c41bca4569a743b400 Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3 Locale: English/Canada (en_CA) Installed mods: * workfeature * Curves 0.3.0 * offline-documentation 1.0.0-alpha * workfeature-macro * Pyramids-and-Polyhedrons
So, until OCCT fixes fillets and chamfers doing it in the sketch is a better option...
Thank you for responding, drmacro.
However, attempting to modify a sketch that has been deemed good for doing revolve/extrude, after the solid has been generated, the task is not so simple. A simpler approach is desirable. A tweak on the Chamber tool would be the ideal approach in the post-solid scenario.
I will partly acknowledge that undercuts should be included in a sketch of the cross-section of a part. If a particular undercut/chamfer/fillet is standard practice on a given section of a family of parts, including those on the sketch is admittedly the thing to do, when doing the initial sketch, when incorporating those features without issues of removing/adding constraints don't interfere with the "sketching" process.
I don't think that "better" is the word that applies. Instead, "forced" option is a better characterization, because it is the only way to achieve the goal, without modifying the OCCT code. Hence my suggestion of a FreeCAD-captive image of the OCCT for tackling such things which OCCT deems "undeserving" or "inappropriate" in their eyes.
If it is problematic to modify the sketch, the sketch is likely over complicated. Simple, minimalist sketches are easier to read, maintain, and modify (and constrain properly) . In fact, I'd put the undercut in a separate sketch.
FreeCAD barely has enough devs to handle FreeCAD, so doing a fork of OCCT is unlikel, I'd guess.
As I understand, OCCT doesn't consider it underserved or inappropriate. They see it as a major refactor of nontrivial code that is not currently on their radar.
Your response suggest you have much awareness with the OCCT development activities. Would you not say that their prioritizing of such a request is skewed because they are focusing efforts on the development of for-profit products built on top of the Open-Source OCCT? Does that activity not suggest a possible motivation to keep any tweaks of the code such as I have suggested within their own "offline-image" used for those for-profit products ... and to use that as a way to pursuade others to migrate to their $$$ tools because they have "the fix" that is not being shared?
- adrianinsaval
they are definitively prioritizing monetization as any corporation has to do, but they don't provide anything that would fix this issue so I don't see how that would be the case, besides I don't see how they would provide filleting capabilities without doing it in the kernel, which is open source...
Then about suggesting that freecad makes it's own version of occt, well who0s going to do that? geometric kernel development is not a trivial task, we hardly have enough people to develop freecad were are we going to get people to fork occ and these type of things? that being said, there is one repo with a version of occt that has some patches that fixes some issues for freecad and it's used for some of the official freecad packages, that repo is at gitlab.com/blobfish/occt but note that it only contains small patches, nobody is currently planning to do any serious work on refactoring fillets.
Also note that in the past there was an "community edition" fork of opencascade that had some code contributed by the community but that they didn't want to sign occ's CLA but this project was eventually abandoned (AFAIK) since they didn't have enough manpower to keep up with the official version.
From what I heard around here, their customers aren't pressing that much for fillet fixes, and us non-customers requests won't matter much to directives.
