Confusing zoom icons
luisrosety
Post by luisrosety »
I have FreeCAD 0.20 (development version) but what I describe is in all tested versions in Ubuntu/Kubuntu.
OS is Kubuntu 22.04
Computer: iMac 24" (2011)
Zoom icons are exactly the same even though one is for "Fiit All" and the other one for "Fit Selection".
Is there a way to get a different icon for each feature?
Thanks
Same icon for 2 different zoom actions<br />Same Icon for two different actions
Re: Confusing zoom icons
Hi and welcome to the forum!
Your full FreeCAD infos may help the helpers.
Willem
Post by Willem »
The same problem on my system. During an update of freead 0.19 last week a lot of icons have changed. Freecad 0.20 daily build still have the old icons
My system:
OS: Ubuntu Core 20 (ubuntu:GNOME/ubuntu)
Version: 0.19.24267 +148 (Git)
Branch: tag: 0.19.4
Hash: 476ecf091941bead59b14e44afa6064d5a66afa3
Python version: 3.8.10
Qt version: 5.15.3
OCC version: 7.5.2
OS: Ubuntu 20.04.4 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.
Branch: unknown
Hash: 7d6243d6961f5c7616b2bcbc844f9abc47eeff9b
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, OCC 7.5.2
Installed mods:
  * fcgear 1.0.0
  * sheetmetal 0.2.49
adrianinsaval
Post by adrianinsaval »
FreeCAD is using your system's icon theme, in Fine-tuning you can find the parameter you need to set to make FreeCAD use it's own icons and ignore all system theme's icons
Willem
Post by Willem »
Here is a picture with both Freecad 0.19 and Freecad 0.20. I have the toolbars placed in the drawing space and you see the differences between the 2 versions. In both installed versions the standard icons are used.
Schermafdruk van 2022-05-22 10-24-38.png (278.28 KiB) Viewed 533 times
adrianinsaval
full info for both? is one of them a snap? did you set the parameter I told you?
