To make solids using sketch or drawing directly in 3d?
niilav
Post by niilav »
Hello everyone!!!
my first post in this forum. Thanks in advance!!!
I've been a Catia user for a long time. To create solid I have always used sketch to draw.
I want to do a small project with FreeCad to see if I can work with it. Is it suitable to use Sketch in FreeCad, or draw lines and so on directly in the 3d environment.
I have watched tutorials on youtube and they seem to use drawing without sketch quite a lot.
Can anyone advise me which is better?
Re: To make solids using sketch or drawing directly in 3d?
Hi and welcome to the forum!
niilav wrote: Fri May 20, 2022 4:53 pm Is it suitable to use Sketch in FreeCad, or draw lines and so on directly in the 3d environment.
There are far more bad videos about FreeCAD on youtube than good ones. You can very well use sketches for feature based modeling in PartDesign workbench. From what I see here in the forum, that's what most of the experts do!
drmacro
Post by drmacro »
chrisb wrote: Fri May 20, 2022 10:17 pm ...
Hmm...just for a full picture, there is no reason not to use a sketch in Part workbench as well.
And, most would consider using a sketch in Part or Part Design workbench the normal workflow.
niilav
Post by niilav »
Thank you for answering the question!
Ok, so then I will use sketc that I understand that the most appropriate way and will not give me problems if the set of solids and relations becomes something more complex.
Thanks!
