How to copy, paste, drag or move "MultiTransform" directly, please help
"MultiTransform.gif" >>> Operation Video
Single operation "LinearPattern", "PolarPattern"...etc
can be directly re-operated
Extend from this topic
https://forum.freecadweb.org/viewtopic.php?f=3&t=68800
- xsuper9988
- CP01.png (163.5 KiB) Viewed 977 times
- CP02.png (160.29 KiB) Viewed 977 times
- CP03.png (150.09 KiB) Viewed 977 times
- MultiTransform.gif (862.19 KiB) Viewed 977 times
- MultiTransform.FCStd
- (93.84 KiB) Downloaded 12 times
- xsuper9988
Re: How to copy, paste, drag or move "MultiTransform" directly, please help
"LinearPattern" can be directly copied, pasted, dragged, moved
But there is a bad thing it will change the color of the original object
"LinearPattern.gif">>>Operation Video
- LP.png (101.76 KiB) Viewed 969 times
- LinearPattern.gif (445.01 KiB) Viewed 969 times
What you want to do is not supported at the moment I think. And since a PartDesign Body is always a chain of features the requested operations may be quite difficult to implement.
I was not able to follow your animations very well, but you seem to be close to this solution:
Workaround to copy-paste a MultiTransform feature:
- Open MultiTransform.FCStd.
- Delete MultiTransform001 belonging to Bady001.
- Copy MultiTransform belonging to Bady with Ctrl+C. Deselect almost all objects in the "Object selection" dialog. See image.
- Create a temporary document and paste the feature there. This will gets rid of the Pocket link.
- Copy the feature from that temporary document and paste it in the main document.
- Right-click MultiTransform001 in the Tree view, choose "Move object to other body" and select Bady001.
- Do the same for LinearPattern001 and PolarPattern001.
- Double-click MultiTransform001.
- Press the "Add feature" button and select Pocket001 in the Tree view.
- Go back to the task panel.
- Double-click LinearPattern001 and select "Base X axis" for the Direction. Press OK at the bottom of the task panel.
- Double-click PolarPattern001 and select "Base Z axis" for the Axis. Again press OK at the bottom of the task panel.
- Press the OK button to finish.
- Right-click MultiTransform001 in the Tree view, choose "Set tip".
- The pasted feature comes with its own view properties, so Bady001 now has the same color as Bady.
- object-selection.png (24.69 KiB) Viewed 786 times
An alternative solution is to use PartDesign_SubShapeBinders to transfer the hole pattern.
- MultiTransform-SubShapeBinder.FCStd
- (123.17 KiB) Downloaded 10 times
- xsuper9988
I found this not only to get rid of the Pocket link
Most importantly it gets rid of "Bady"
I learned how to get rid of links
I also learned the syntax of "List"
Many thanks Roy
but i have a question
Why "LinearPattern","PolarPattern" can get rid of "Bady" without opening a temporary document?
- xsuper9988
I have never used SubShapeBinder beforeRoy_043 wrote: ↑Tue May 31, 2022 9:54 pm An alternative solution is to use PartDesign_SubShapeBinders to transfer the hole pattern.
This seems like an interesting feature
I'll study it and test it
Thank you so much for replying to this variety of methods
I don't know.xsuper9988 wrote: ↑Wed Jun 01, 2022 12:08 pm Why "LinearPattern","PolarPattern" can get rid of "Bady" without opening a temporary document?
