I've created a part using Part Design Workbench and it is saved as FreeCad document *FCStd. How do I go about saving or converting this file to object format *.obj or STL format *.stl so i can import the part to 3D printer which supports these file extensions?
First time user of FreeCad and would appreciate any help on this issue.
Thanks
3D File Conversion Issue
Re: 3D File Conversion Issue
Just select the part and use File --> Export to save it in one of these formats.
Welcome to the forum! Please read the stuff we're asking for first (have a look at my signature). the answer to your question is the first thing in the FAQs https://forum.freecadweb.org/viewtopic. ... 06#p170906
Regards / Viele Grüße
Max
Max
- thomas-neemann
here you can see a step export from min 0:50. stl or obj can also be created with the method
https://www.youtube.com/watch?v=IkDIGw21sUA
Thanks for the replies and links to helpful info. Much appreciated from first time user.
Great that it works now! You're welcome to add a "[Solved]" at the beginning of the thread title to mark this thread as solved.
Max
Max
