yes, i had bad experiences with sketcher flipping
parametric object does not use linked values
- thomas-neemann
Re: parametric object does not use linked values
Yes, it is known problem - I used to suffer from it as well
- thomas-neemann
it's not a specific freecd problem. autodesk inventor etc have it too. it is probably the technique to work with solvers
thomas-neemann wrote: ↑Mon May 23, 2022 8:46 am it's not a specific freecd problem. autodesk inventor etc have it too. it is probably the technique to work with solvers
Yes, I know
it's in the nature of the beast that has more than one (perfectly valid) solution to the geometric problem.
- thomas-neemann
yes, unfortunately it is rarely mentioned. i have requests for freecad training. I will point out in it at the beginning.
Could this be related to my problem here https://forum.freecadweb.org/viewtopic.php?f=3&t=68835? Changing value does not recolculate expression of an object that has some errors. Although if the change was applied as it should have been the error would have been resolved.
quite possible!
I am familiar with this behaviour as well (I normally use Linkstage3 branch) - is it the same for master branch?
It makes sense to me - since how do you expect solver to solve something that is not solvable because of errors?
- adrianinsaval
No bug, you just used an incorrect set of constraints for what you intend to draw, you used a length and an equality constraint to make a closed rectangle when you should have used coincidence on all vertex instead.
- adrianinsaval
the underlying mechanic that stops the recomputation is the same, if an object fails to recompute anything that depends on it will not be recomputed, but it wouldn't make a difference if the values from the expression were updated, a previous sketch (or in your case a fillet) was broken so nothing past that would get recomputed.kisolre wrote: ↑Mon May 23, 2022 10:37 am Could this be related to my problem here https://forum.freecadweb.org/viewtopic.php?f=3&t=68835? Changing value does not recolculate expression of an object that has some errors. Although if the change was applied as it should have been the error would have been resolved.
But the dynamic data objects do not depend on the body in any way. The Body placement does not depend on the Bosy shape. So errors in shape should not prevent placement from recomputation since it should happen before calcumation the shape. And shape can (and does) depend on placement so calculating proper placement will result in proper shape (no errors).adrianinsaval wrote: ↑Mon May 23, 2022 2:09 pm the underlying mechanic that stops the recomputation is the same, if an object fails to recompute anything that depends on it will not be recomputed,
