That errors are after the placement is calculated. If the proper placement was calculated all else should work out and there shouldnt be any errors (apart from some TN weirdness, but again this should not affect placement).
parametric object does not use linked values
Re: parametric object does not use linked values
- adrianinsaval
That's simply not how it works, when there is a failure in a dependency the entire object is not recomputed (and the placement is a property of the shape actually). FreeCAD doesn't detect per property dependencies but at the object level. And like I said, the issue in your file is not the outdated expression, it's the fillet, try clearing the expression in the body placement and manually changing the value to -21.6, the model is still broken and recomputation still stops at the fillet, to get it working you must fix/remove the fillet.
I don't think this is true, from my understanding, the body is in the recompute queue after everything else inside it, not before.That errors are after the placement is calculated.
- thomas-neemann
in my opinion you can build very stable parametric models with controlling bodies from part or lines and points from draft, which control sketches. another advantage is that it can be controlled 3-dimensionally at one point
here is an example
https://forum.freecadweb.org/viewtopic. ... 61#p596961
Everybody on internet has an opinion
You are perfectly entitled to have yours...
(I also have one )
- adrianinsaval
Absolutely, sketches are just more convenientthomas-neemann wrote: ↑Mon May 23, 2022 3:49 pm in my opinion you can build very stable parametric models with controlling bodies from part or lines and points from draft, which control sketches. another advantage is that it can be controlled 3-dimensionally at one point
