[ Bug ] Addon Manager: problem if multiple WBs are updated
Roy_043
Post by Roy_043 »
If the Addon Manager automatically updates multiple workbenches the same package is used for all workbenches. So f.e. if the Curves WB and The Fasteners WB are updated, the Fasteners package is installed for both.
To test:
Install the Curves WB and the Fasteners WB.
Exit FreeCAD.
Edit:
C:\Users\name\AppData\Local\Temp\FreeCAD\Cache\AddonManager\PackageMetadata\Curves\package.xml
C:\Users\name\AppData\Local\Temp\FreeCAD\Cache\AddonManager\PackageMetadata\fasteners\package.xml
Change the version numbers to a lower version.
Restart FC.
In the AM press "Check for updates".
Press "Apply 2 update(s)".
Restart FC.
Result: warning:
During initialization the error ""'FastenersWorkbench' already exists."" occurred in C:\Users\name\AppData\Roaming\FreeCAD\Mod\fasteners\.\InitGui.py
Side note: the package.xml files are not updated after the operation.
@chennes can you have a look?
OS: Windows 8.1 (6.3)
Version: 0.20.28918 (Git)
Hash: e1f2685734
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Installed mods:
kisolre
Re: [ Bug ] Addon Manager: problem if multiple WBs are updated
Post by kisolre »
@chennes any ideas about that? I have several (8 WB + 1 macro) updates available and dont want to waste traffic sorting such issue later. Or should I just update them one by one as a workaround?
I also noticed that the item list is not properly updated? I have "Workbenches/update available" configuration and see the count on the Apply button rising but the list is not updated until I change its state to something else and back.
From the VM:
OS: Windows 10 Version 2009
Version: 0.20.28936 (Git)
Hash: b02705d79f2e1adc7773f0c845e0acc5ae8fde4b
Python 3.8.6+, Qt 5.15.2, Coin 4.0.1, OCC 7.5.3
chennes
Post by chennes »
(Sorry for the delay, I was traveling.)
Thanks for the detailed report, that was very helpful. I think I've isolated the multiple-WB update issue, and have a workaround for it:
https://github.com/FreeCAD/FreeCAD/comm ... ae8a03b803
I'm still chasing a couple of minor AM bugs, but I think that commit will fix the issues with trying to update multiple WBs at the same time, I was not appropriately handling some multi-threading issues. The current workaround is to just use a single thread for the updates, so they can't conflict with one another.
Chris Hennes
Pioneer Library System
chennes
Post by chennes »
kisolre wrote: Fri May 27, 2022 7:22 pm I also noticed that the item list is not properly updated?
I am not seeing that (keep in mind that you are only showing WBs, and some of the available updates may be for macros) -- I'll take a look at the code to make sure there is a refresh implemented after the update check, though.
Chris Hennes
kisolre
Post by kisolre »
chennes wrote: Fri May 27, 2022 8:29 pm keep in mind that you are only showing WBs, and some of the available updates may be for macros)
kisolre wrote: Fri May 27, 2022 7:22 pm (8 WB + 1 macro)
Only 3 WB are shown.
chennes
Post by chennes »
kisolre wrote: Sat May 28, 2022 1:17 am Only 3 WB are shown.
Do you actually have to click something to get the others to show, or does moving the mouse over the window trigger it?
Chris Hennes
kisolre
Post by kisolre »
chennes wrote: Sat May 28, 2022 1:21 am Do you actually have to click something to get the others to show,
I tried now moving the window, resizing the window, clicking in list area - no updates in the list. When Addon manager was started it was in Workbenches/Any state, properly displayed all workbenches. While the check was going I switched to Workbenches/Update available and the list emptied (no updates were found until then). Then tried above mentioned actions - list stayed empty until all check were finished and then updated.
Version: 0.20.28939 (Git)
Hash: 4c2972cb2391ecad30f1015be8b67cae8a03b803
Installed mods:
  * 3DfindIT 1.2.0
  * A2plus 0.4.56
  * AirPlaneDesign 0.4.0
  * AnimationFreeCAD 1.0.0
  * ArchTextures
  * Assembly3 0.11.3
  * Assembly4 0.11.12
  * BIM 2021.12.0
  * BOLTSFC
  * CfdOF 1.16.4
  * CubeMenu
  * CurvedShapes 1.0.3
  * Curves 0.3.0
  * CycloidGearBox
  * Defeaturing
  * Design456
  * DesignSPHysics 0.6.1-2201-31-01
  * dodo
  * DynamicData 2.46.0
  * ExplodedAssembly
  * fasteners 0.3.41
  * FCGear 1.0.0
  * FCPDWorkbench 0.2.0
  * FEM_FrontISTR 0.1.0
  * frame
  * freecad.xray 2022.4.17
  * FreeCAD_mcm_addon
  * Help 1.0.0-alpha
  * InvGears 0.1.2
  * kicadStepUpMod 10.12.4
  * lattice2 1.0.0
  * Launcher
  * MakerWorkbench
  * Manipulator 1.4.3
  * Mechatronic
  * MeshRemodel 1.8919.0
  * MnesarcoUtils 0.1.0
  * Nikra-DAP
  * nurbs
  * OpticsWorkbench 1.0.8
  * ose-piping
  * parts_library
  * PlacementTools
  * Plot 2022.4.17
  * Pyramids-and-Polyhedrons
  * Reinforcement
  * Render 2022.1.0
  * Rocket 2.4.1
  * SearchBar 1.0.1
  * SelectorToolbar
  * sheetmetal 0.2.49
  * Ship 2022.4.11
  * Silk
  * SlopedPlanesMacro
  * StemfieWB
  * symbols_library
  * ThreadProfile 1.81.0
  * toSketch
  * Woodworking 1.0.0
  * workfeature
  * workfeature-macro
chennes
Post by chennes »
kisolre wrote: Sat May 28, 2022 10:03 am list stayed empty until all check were finished and then updated.
Oh, I must have misunderstood -- this sounds like the correct behavior. I am explicitly not refreshing that list on each individual update, if I do so it constantly recalculates and flickers, which is very annoying. There should be one single refresh at the end of the update. Is that what you are seeing?
Chris Hennes
kisolre
Post by kisolre »
Yes, exactly. Maybe because of slow connection I was waiting too long and expecting the list to update.... If this is by design - no problem. I was just expecting different.
