Spreadsheet .Start.xyz, .End.xyz
bgma1961
Post by bgma1961 »
I have a problem with "Start.y", when I enter a value or a formula in the "Formula Editor" in
Properties: Start, the value does not change even if
I do a refresh (F5) / Mark to recompute / recompute object.
I have been able to reproduce the error which seems to be due to the fact that I entered
"Base / Placement / Position / z" = "<<Spreadsheet>> .FH_1"
If I press [Clear] and enter a value, it works.
I have seen the problem for quite some time now without being able to point it out.
then I saw posts: parametric object does not use linked values that gave me the idea to look at Spreadsheet.
https://forum.freecadweb.org/viewtopic.php?f=3&t=68872
/ Best regards BG
OS: Windows 7 SP 1 (6.1)
Version: 0.20.28918 (Git)
Hash: e1f2685734
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Locale: Swedish/Sweden (sv_SE)
Test7.FCStd
(11.4 KiB) Downloaded 32 times
thomas-neemann
Re: Spreadsheet .Start.xyz, .End.xyz
Post by thomas-neemann »
bgma1961 wrote: Mon May 23, 2022 9:37 pm ...
I didn't understand the question, there were problems with the alias in the spreadsheet. does it work if you use the cell directly?
bgma1961
Post by bgma1961 »
thomas-neemann wrote: Tue May 24, 2022 6:54 am
No it does not work with <<Spreadsheet>> .B1 in "#Line.Base.Placement.Position.z".
If I enter a value directly in .z, it works.
As you can see, "# Line.Start.z has 2500mm <<Line001>> .End.y" but "<<Line001>> .End.y" = 0
thomas-neemann
bgma1961 wrote: Tue May 24, 2022 8:48 am ...
in realthunder i can change the value
tn-Test7.FCStd
(12.31 KiB) Downloaded 29 times
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 2022.111.30764 (Git) AppImage
Branch: LinkDaily
Hash: ef3092bcbca5475eff4eb7ff7933eb3e9bbbe4b9
Python version: 3.9.9
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
thomas-neemann
in 0.19.3 it also works after recompute
Version: 0.19.24366 (Git) AppImage
Branch: (HEAD detached at 0f9259c)
Hash: 0f9259cda103ae1824ac16c68ac9b4a0d54b05fc
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
jaisejames
Post by jaisejames »
You can enter value directly in Start [<<Line001>> .End].
I think separate vector x,y,z value is not supported in expression.
freecad vector.png (10.67 KiB) Viewed 1233 times
bgma1961
Post by bgma1961 »
thomas-neemann wrote: Tue May 24, 2022 9:04 am
I tried in version 0.19.24291 and it works
I don't have 0.19.24366
Version: 0.19.24291 (Git)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
bgma1961
Post by bgma1961 »
bgma1961 wrote: Tue May 24, 2022 9:39 am
Qt version: 5.12.9
OCC version: 7.4.0
I also tested "#Line.Start.x" which works but "#Line.Start.y" does not work
thomas-neemann
bgma1961 wrote: Tue May 24, 2022 10:00 am ....
what should come out of it? I suppose there is an easier way. I haven't needed anything like this yet
bgma1961
Post by bgma1961 »
thomas-neemann wrote: Tue May 24, 2022 10:05 am
As you already know (Mail 2022-04-08), my .FCStd is ( 12479kb) very large to publish here. and consists of a number of floors and a number of walls on each floor. What should come out is to be able to change floor heights and wall plagiarism and wall thicknesses and more via parameters and more.
It does not work with Start.Y but with Start.X [BUG]?
This .FCStd is only an example of what is not working.
