Spherical Knurl
mnew
Spherical Knurl
Post by mnew »
Hi all,
I'm trying to create a knurl on the surface of a sphere based on an icosahedral groove. To do this, I created a sphere and I need to run grooves about a few different datum lines. When I go to make the second groove, my computer exudes heat for about 10 minutes then eventually FreeCAD draws some lines across the surface of the sphere (i.e. the groove doesn't actually eliminate material from the sphere). I'm a bit stuck here, any help appreciated.
When I leave the second groove in the FCStd file, the size skyrockets to 2 MB, so I can't attach it. In the attached, add a groove of Sketch XZSlots2 about DatumLine001. This should exhibit the behavior I describe above.
KnurledSphere.FCStd
(149.87 KiB) Downloaded 25 times
M4x
Re: Spherical Knurl
Post by M4x »
Welcome.to the forum!
Please have a look at the big red banner at the top and provide your full FreeCAD information.
Thanks!
mnew
Re: Spherical Knurl
Post by mnew »
M4x wrote: Tue May 24, 2022 10:13 pm Welcome.to the forum!
Thanks!
Info isn't working for me. I can tell you that I'm on v0.19.3 for OSX.
Screen Shot 2022-05-24 at 9.24.31 PM.png (65.59 KiB) Viewed 1084 times
M4x
Re: Spherical Knurl
Post by M4x »
I've never seen this error before. @chrisb you're on a Mac too if I recall correctly. Have you seen this error before?
hammax
Re: Spherical Knurl
Post by hammax »
... KISS in PartWB:
KnurledSphere_4.FCStd
FC.20
(39.91 KiB) Downloaded 13 times
KnurledSphere_3.FCStd
FC.20
(47.53 KiB) Downloaded 13 times
KnurledSphere.FCStd
FC.20_28886
(28.84 KiB) Downloaded 12 times
papyblaise
Re: Spherical Knurl
Post by papyblaise »
I'm modest, I do grove after grove, on a half sphere and end up with a Mirror, which I don't know how to do in PD Wb
KnurledSphere1.FCStd
(87.72 KiB) Downloaded 13 times
Re: Spherical Knurl
M4x wrote: Wed May 25, 2022 8:53 am Have you seen this error before?
No. I don't have the file mentioned in the error message. in my 0.20 installation. I recommend to clean the config files, and perhaps the whole directory.
edwilliams16
Re: Spherical Knurl
Post by edwilliams16 »
No errors. Second groove is slow... Passes Geometry check - slow.
Screen Shot 2022-05-25 at 8.16.26 AM.png (61.61 KiB) Viewed 869 times
[code]
OS: macOS High Sierra (10.13)
Version: 0.20.28909 (Git)
Hash: 6beef68ae1
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Locale: C/Default (C)
Installed mods:
  * Curves 0.3.0
  * DynamicData 2.45.0
  * fasteners 0.3.40
  * fcgear 1.0.0
  * Help 1.0.0-alpha
  * lattice2 1.0.0
  * MeshRemodel 1.8919.0
  * toSketch
[/code]
Re: Spherical Knurl
Post by Kunda1 »
hammax
Re: Spherical Knurl
Post by hammax »
... I understand, it must be FreeCAD on the BBQ screen on heavy load when "knurling".
I think the cutting task is the showstopper.
Here another trial.
KnurledSphere_5.FCStd
FC.20 28886
(24.39 KiB) Downloaded 15 times
